sherryliu
Member level 1
- Joined
- Jan 17, 2011
- Messages
- 32
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,535
#include<reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit DATA = P1^1;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
int temp;
int ss;
int dd;
int j;
uchar data b;
uchar data buf[4];
int alarmH=320;
int alarmL=100;
sbit k1=P2^5;
sbit k2=P2^6;
sbit k3=P2^7;
sbit k4=P2^4;
sbit bell=P1^0;
sbit HLight=P1^2;
sbit LLight=P1^3;
sbit warn=P1^4;
sbit Red=P1^6;
sbit Green=P1^7;
bit set=0;
bit Flag=0;
int n;
void key_to1();
void key_to2();
void delay(uint);
void key();
void Show();
void delay(uint num)
while(num--) ;
Init_DS18B20(void)
uchar x=0;
DATA = 1;
delay(10);
DATA = 0;
delay(80);
DATA = 1;
delay(20);
x=DATA;
delay(30);
ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DATA = 0;
dat>>=1;
DATA = 1;
if(DATA)
dat|=0x80;
delay(8);
return(dat);
WriteOneChar(unsigned char dat)
uchar i=0;
for (i=8; i>0; i--)
DATA = 0;
DATA = dat&0x01;
delay(10);
DATA = 1;
dat>>=1;
delay(8);
int ReadTemperature(void)
uchar a=0;
uchar b=0;
int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5;
return(t);
void display00()
dd=-(temp-1);
buf[1]=dd/100;
buf[2]=dd/100;
buf[3]=dd%100/10;
buf[0]=dd%10;
for(j=0;j<5;j++)
P2=0xff;
P0=0x00;
P2=0xfd;
P0=0x80;
delay(100);
P2=0xff;
P0=0x00;
P2=0xf7;
P0=0x40;
delay(100);
P2=0xff;
P0=0x00;
P2=0xfb;
P0=table[buf[2]];
delay(100);
P2=0xff;
P0=0x00;
P2=0Xfd;
P0=table[buf[3]];
delay(100);
P2=0xff;
P0=0x00;
P2=0Xfe;
P0=table[buf[0]];
delay(100);
P2=0xff;
void display()
buf[1]=temp/1000;
buf[2]=temp/100%10;
buf[3]=temp%100/10;
buf[0]=temp%10;
for(j=0;j<3;j++)
P2=0xff;
P0=0x00;
P2=0xfd;
P0=0x80;
delay(300);
P2=0xff;
P0=0x00;
P2=0xf7;
P0=table[buf[1]];
delay(300);
P2=0xff;
P0=0x00;
P2=0xfb;
P0=table[buf[2]];
delay(300);
P2=0xff;
P0=0x00;
P2=0Xfd;
P0=table[buf[3]];
delay(300);
P2=0xff;
P0=0x00;
P2=0Xfe;
P0=table[buf[0]];
delay(300);
P2=0xff;
void key()
{ if(k1!=1)
delay(20);
if(k1!=1)
while(k1!=1)
{ key_to1();
for(n=0;n<8;n++)
Show();
if(k2!=1)
delay(20);
if(k2!=1)
while(k2!=1)
{ key_to2();
for(n=0;n<8;n++)
Show();
if(k3!=1)
{ TR0=1;
temp=ReadTemperature();
if(k4!=1)
{ delay(20);
if(k4!=1)
while(k4!=1);
set=!set;
if(set==0)
Red=0;Green=1;
else
Green=0;Red=1;
void key_to1()
TR0=0;
temp+=10;
if(temp>=1100)
{temp=-550;}
if(set==0)
{alarmH=temp;}
else {alarmL=temp;}
void key_to2()
TR0=0;
temp-=10;
if(temp<=-550)
{temp=1100;}
if(set==0)
{ alarmH=temp;}
else { alarmL=temp;}
void alarm(void)
if(temp>alarmH||temp<alarmL)
{ //bell=1;
//delay(50);
//bell=0;
Flag=1;
}else {Flag=0;}
logo()
{ P0=0x40;
P2=0xf7;
delay(50);
P2=0xfb;
delay(50);
P2=0Xfd;
delay(50);
P2=0Xfe;
delay(50);
P1 = 0xff;
void Show()
{ if(temp>=0)
{HLight=1;LLight=0;display();}
if(temp<0)
{HLight=0;LLight=1;display00();}
void main()
TCON=0x01;
TMOD=0X01;
TH0=0XD8;
TL0=0XF0;
EA=1;
ET0=1;
TR0=1;
EX0=1;
for(n=0;n<500;n++)
{bell=1;warn=1;logo();}
Red=0;
while(1)
key();
ss=ReadTemperature();
Show();
alarm();
if(Flag==1)
{bell=!bell;
warn=!warn;}
else {bell=1;
warn=1;}
void time0(void) interrupt 1 using 1
{ TH0=0X56;
TL0=0XDC;
temp=ss;
Hi guys,could you help me explain this mean?Suppose ,measuring 85.C,first a=50,b=05,t=0550,then tt=550*0.0625=34.375 or tt=550H*0.0625=1360*0.0625=85,finally t=tt*10+0.5=34.375*10+0.5=344.25 or t=tt*10+0.5=85*10+0.5=850.5,Thanks!!!
sbit DATA = P1^1;
int temp;
int ss;
int dd;
int j;
uchar data b;
uchar data buf[4];
int alarmH=320;
int alarmL=100;
sbit k1=P2^5;
sbit k2=P2^6;
sbit k3=P2^7;
sbit k4=P2^4;
sbit bell=P1^0;
sbit HLight=P1^2;
sbit LLight=P1^3;
sbit warn=P1^4;
sbit Red=P1^6;
sbit Green=P1^7;
bit set=0;
bit Flag=0;
int n;
void key_to1();
void key_to2();
void delay(uint);
void key();
void Show();
while(num--) ;
Init_DS18B20(void)
uchar x=0;
DATA = 1;
delay(10);
DATA = 0;
delay(80);
DATA = 1;
delay(20);
x=DATA;
delay(30);
ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DATA = 0;
dat>>=1;
DATA = 1;
if(DATA)
dat|=0x80;
delay(8);
return(dat);
uchar i=0;
for (i=8; i>0; i--)
DATA = 0;
DATA = dat&0x01;
delay(10);
DATA = 1;
dat>>=1;
delay(8);
uchar a=0;
uchar b=0;
int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5;
return(t);
void display00()
dd=-(temp-1);
buf[1]=dd/100;
buf[2]=dd/100;
buf[3]=dd%100/10;
buf[0]=dd%10;
for(j=0;j<5;j++)
P2=0xff;
P0=0x00;
P2=0xfd;
P0=0x80;
delay(100);
P2=0xff;
P0=0x00;
P2=0xf7;
P0=0x40;
delay(100);
P2=0xff;
P0=0x00;
P2=0xfb;
P0=table[buf[2]];
delay(100);
P2=0xff;
P0=0x00;
P2=0Xfd;
P0=table[buf[3]];
delay(100);
P2=0xff;
P0=0x00;
P2=0Xfe;
P0=table[buf[0]];
delay(100);
P2=0xff;
void display()
buf[1]=temp/1000;
buf[2]=temp/100%10;
buf[3]=temp%100/10;
buf[0]=temp%10;
for(j=0;j<3;j++)
P2=0xff;
P0=0x00;
P2=0xfd;
P0=0x80;
delay(300);
P2=0xff;
P0=0x00;
P2=0xf7;
P0=table[buf[1]];
delay(300);
P2=0xff;
P0=0x00;
P2=0xfb;
P0=table[buf[2]];
delay(300);
P2=0xff;
P0=0x00;
P2=0Xfd;
P0=table[buf[3]];
delay(300);
P2=0xff;
P0=0x00;
P2=0Xfe;
P0=table[buf[0]];
delay(300);
P2=0xff;
void key()
{ if(k1!=1)
delay(20);
if(k1!=1)
while(k1!=1)
{ key_to1();
for(n=0;n<8;n++)
Show();
if(k2!=1)
delay(20);
if(k2!=1)
while(k2!=1)
{ key_to2();
for(n=0;n<8;n++)
Show();
if(k3!=1)
{ TR0=1;
if(k4!=1)
{ delay(20);
if(k4!=1)
while(k4!=1);
set=!set;
if(set==0)
Red=0;Green=1;
else
Green=0;Red=1;
void key_to1()
TR0=0;
temp+=10;
if(temp>=1100)
{temp=-550;}
if(set==0)
{alarmH=temp;}
else {alarmL=temp;}
void key_to2()
TR0=0;
temp-=10;
if(temp<=-550)
{temp=1100;}
if(set==0)
{ alarmH=temp;}
void alarm(void)
{ //bell=1;
//delay(50);
//bell=0;
Flag=1;
}else {Flag=0;}
logo()
{ P0=0x40;
P2=0xf7;
delay(50);
P2=0xfb;
delay(50);
P2=0Xfd;
delay(50);
P2=0Xfe;
delay(50);
P1 = 0xff;
void Show()
{ if(temp>=0)
if(temp<0)
void main()
TCON=0x01;
TMOD=0X01;
TH0=0XD8;
TL0=0XF0;
EA=1;
ET0=1;
TR0=1;
EX0=1;
for(n=0;n<500;n++)
Red=0;
while(1)
key();
Show();
alarm();
if(Flag==1)
{bell=!bell;
warn=!warn;}
else {bell=1;
warn=1;}
{ TH0=0X56;
TL0=0XDC;
temp=ss;
