syenidogan
Member level 1
- Joined
- Mar 6, 2014
- Messages
- 41
- Helped
- 2
- Reputation
- 4
- Reaction score
- 3
- Trophy points
- 8
- Activity points
- 297
Do you mean to say that it is not displaying correct values on the LCD,or there is something wrong with the sensor?
Please explain..
unsigned char read_temperature(void)
İ need MSB of first byte (4 bits) and lsb of second byte (4bits). And first 4 bits will be my lsb and second 4 bits will be my MSB on the result byte.hello
did you check the result of
before displaying on LCD ?Code:unsigned char read_temperature(void)
i don't know the OWS DS18b20, but could you confirm :
you take 2 bytes from DS18b20, but only keep MSB of each value to form the result
is it the good way ?
does it needs to use an integer to contain the result ?
yes you can read all the bytes if you want or you can just reset bus after getting what you need.hello,
I read the datasheet, and it seems that all the Scratchpad must be read (9 bytes) ?
Unfortunatly, i don't have this device to check by myself.
You don't check (read) the DS18b20 "Presence pulse" before start Skip ROM + Read Scratchpad ..
to be sure DS18B20 is visible on the OWS bus.
Are you confident with your delay_uS to build mS delay ?
maybe you can use a timer to do delay 750mS ?
Have a look on this LINK
