#include <16F876a.h>
#include <ds1307.h>
#fuses NOWDT,XT, PUT, NOPROTECT, BROWNOUT ,NODEBUG ,NOLVP
#use delay(clock=4000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8)
#zero_ram
int DATE,MTH,YR,HR,MT,SECDS,DOW; //
void main() {
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
ds1307_init();
while(1){
ds1307_get_time(HR,MT,SECDS);
ds1307_get_date(DATE,MTH,YR,DOW);
printf("\rTime %2D:%02D:%02D",HR,MT,SECDS);
printf(" Date %2D/%02D/%02D",DATE,MTH,YR);
delay_ms(100);
if(!input(PIN_C0 ))
ds1307_set_date_time(28,1,8,2,11,50,0); // Time 11:50:00 Date 28/01/08
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Disable squarewave output ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec) Set the date/time ///
/// ds1307_get_date(day,mth,year,dow) Get the date ///
/// ds1307_get_time(hr,min,sec) Get the time ///
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); // REG 3
day = bcd2bin(i2c_read() & 0x3f); // REG 4
mth = bcd2bin(i2c_read() & 0x1f); // REG 5
year = bcd2bin(i2c_read(0)); // REG 6
i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f);
min = bcd2bin(i2c_read() & 0x7f);
hr = bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
BYTE temp;
BYTE retval;
temp = binary_value;
retval = 0;
while(1)
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
break;
return(retval);
// Input range - 00 to 99.
BYTE temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
sadat007 said:Hi. elizabeth
I wish to start properly programming in C but until now I have quite good setup of BASIC compilers and also quite happy with them.
Sorry I could not help u in this..... may be some one else on this forum will do.
For the Proteus yes I have 7.2 but no DS1337. Remember, using DS1337 is very simple just search DS1337.exe on edaboard and you will find my program that will help u a lot in setting the DS1337
If you like I can put here some codes in mikroBasic regarding interrupt and DS1337 handling.
Note that DS1337 and DS1307 are same for date/time writing and reading.
Thanks
sadat007
sadat007 said:Hi,
Please do not ask for copyrighted software. it will be good to edit your post a little.
It is really hard for me to help you as I used mikroBasic, PIC18F4525 and DS1337. So here I am trying to explain you and you will have to implement by your self in CCS.
Please try my program DS1337.exe
Hope this will help u a lot.
Thanks
Sadat007
:arrow::arrow::arrow::!::?::?::idea::idea:
In 16F877 there is one external interrupt INT on RB0 (pin-33 of DIP)
The bit-6 (INTEDG) of OPTION_REG will decide
1 = Interrupt on rising edge of RB0/INT pin
0 = Interrupt on falling edge of RB0/INT pin
I think it should be set to Zero
The bit-7 (RBPU) of OPTION_REG will decide
1 = PORTB pull-ups are disabled
0 = PORTB pull-ups are enabled by individual port latch values
I recommend u to put zero here and connect one external 10k pullup resistor on RB0/INT pin.
Now in INTCON REGISTER
GIE (bit-7) =0 to disable all interrupts and 1= all enable it
INTE (bit-4) =0 to disable INT and 1= all enable it
INTF (bit-1) =1 means The RB0/INT external interrupt occurred (must be cleared in software)
and =0 means external interrupt did not occur. This bit should be check to verify that the INT occurred
and should be clear after all routines performed (that need to be performed).
interrupt sub routine
check for which interrupt occurred in your case it can be INT
so check for INTF flag/bit as described above
so finally if the if INTF=1 then u can call a routine of reading and comparing
the time and if matched generate an alarm
Also that it may be required to clear the bit INTCON.INTF = 0 when all done
Writing to DS1307
I2C_Start
I2C_WR($D0) 'I2C address 1101000 of DS1307 for writing mode Please recheck it
I2C_WR(pointer) 'normally pointer=0 which is the address of seconds
'following 3 lines may not be required
I2C_Repeated_Start
I2C_WR(Seconds)
I2C_WR(Minutes)
I2C_WR(Hours)
I2C_WR(Day Of Week)
I2C_WR(DATE)
I2C_WR(Month)
I2C_WR(YEAR)
I2C_WR(10) '1Hz enabled 10 is in HEX
I2C_Stop
Reading DS1307
I2C_Start
I2C_Wr($D0) 'I2C address 1101000 of DS1307 for WRITING mode Please recheck it
I2C_Wr($00) 'normally pointer=0 which is the address of seconds
I2C_Repeated_Start
I2C_Wr($D1) 'I2C address of DS1307 for READING mode Please recheck it
Sec = I2C_Rd(1)
read one by one up to year
