drkidd22
I have a LM6733 LCD module which has a SED1330 display controller. I'm trying to use the Explorer 16 to display some simple message on the screen just to get me started, but I have not been successful at it.
I have the lower 8 bits of PORTE on the pic set for the data lines and PORTA for the control lines. Below is the code of what I have so far and have not been able to display anything on the screen. I'm using the pictail PBC and have tested everything. 100% sure that the wiring is correct.
MPLAB v8.46
ICD2
LED Jumper from explorer 16 removed
Any help will be appreciated.
This part of the project contains all #Define directives and the LCD Initialization
Date: 03/25/2010
LCD Model: LM6733
LCD Controller: SED1330
#include "p33FJ256GP710.h"
_FOSCSEL(FNOSC_PRIPLL);
_FOSC(FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMD_XT);
_FWDT(FWDTEN_OFF);
#define LCD_DATA PORTE // Port for data transfer.(PIC RE0-RE7 <<------>> LCD DB0-DB7)
#define DDR_DATA TRISE // Port E Data direction controll
#define DDR_CTRL TRISA // Port A Data direction controll
#define GLCD_COMMAND PORTAbits.RA0 /* A0 Pin PIC RA0
#define GLCD_CS PORTAbits.RA1 /* Chip Select PIC RA1
#define GLCD_WR PORTAbits.RA2 /* WR Pin PIC RA2
#define GLCD_RD PORTAbits.RA3 /* RD Pin PIC RA3
#define GLCD_RESET PORTAbits.RA4 /* Reset Pin PIC RA4
#define Hi 1
#define Lo 0
#define LCD_RESX 320 /* Grafic resolution X */
#define LCD_RESY 240 /* Grafic resolution Y */
#define LCD_CHARPERROW 40 /* maximum is ( GLCD_RESX / GLCD_CHARWIDTH ) */
#define LCD_CHARROWS 16 /* should be calculated from RESY/CHARHEIGHT */
#define LCD_CHARWIDTH 8 /* = GLCD_RESX / GLCD_CHARPERROW */
#define LCD_CHARHEIGHT 8
#define SYSSET 0x40 /* System Set */
#define SLEEPIN 0x53 /* Enter standby mode */
#define DISPOFF 0x58 /* Display on */
#define DISPON 0x59 /* Display off */
#define SCROLL 0x44 /* Display Start Addr & Display regions */
#define CSRFORM 0x5D /* Set Cursor Type */
#define CGRAM 0x5C /* Start Addr Char. Generator Ram */
#define CSRDIR 0x4C /* Direction of cursor movement */
#define HDOTSCR 0x5A /* Horizontal Scroll Position */
#define OVERLAY 0x5B /* Display Overlay format */
#define CSRW 0x46 /* Set Cursor Address */
#define CSRR 0x47 /* Read Cursor Address */
#define MWRITE 0x42 /* Write to Display Memory */
#define MREAD 0x43 /* Read from Display Memory */
/* send Command to Controler */
void lcdSndCmd(unsigned char command )
LCD_RD = Hi;
LCD_DATA = command;
LCD_COMMAND = Hi;
LCD_CS = Lo;
LCD_WR = Lo;
//short_delay;
LCD_CS = Hi;
LCD_WR = Hi;
LCD_COMMAND = Lo;
/* send Data to Controller */
void lcdSndData(unsigned char value )
LCD_DATA = value;
LCD_COMMAND = Lo;
LCD_RD = Hi;
LCD_CS = Lo;
LCD_WR = Lo;
//short_delay;
LCD_CS = Hi;
LCD_WR = Hi;
/* Reset Controller */
void LCD_Reset(void)
int i;
volatile int j;
DDR_DATA = 0x00;
DDR_CTRL = 0x00;
LCD_RD = Hi;
LCD_WR = Hi;
LCD_DATA = 255;
LCD_COMMAND = Hi;
LCD_RESET = Lo;
for (i = 0; i < 1000; i++)
{ j++;
LCD_RESET = Lo;
{ j++;
LCD_RESET = Hi;
LCD_RESET = Hi;
LCD_CS = Hi;
void LCD_Init(void)
DDR_DATA = 0x00;
DDR_CTRL = 0x00;
lcdSndCmd(SYSSET);
lcdSndData(0x30);
lcdSndData((LCD_CHARWIDTH-1)|0x80);
lcdSndData(LCD_CHARHEIGHT-1);
lcdSndData(LCD_CHARPERROW-1);
lcdSndData(LCD_CHARPERROW+4);
lcdSndData(LCD_RESY-1);
lcdSndData(LCD_CHARPERROW);
lcdSndData(0);
lcdSndCmd(OVERLAY);
lcdSndData(1);
lcdSndCmd(SCROLL);
lcdSndData(0);
lcdSndData(0);
lcdSndData(0x80);
lcdSndData(0x02);
lcdSndCmd(CSRFORM);
lcdSndData(0x05);
lcdSndData(0x85);
lcdSndCmd(HDOTSCR);
lcdSndData(0x0);
lcdSndCmd(CSRDIR);
lcdSndCmd(DISPON);
lcdSndData(0x14);
// currTextx=0;
// currTexty=0;
lcdSndCmd(MWRITE);
lcdSndData(0x4D); //M
cdSndData(0x49); //I
cdSndData(0x46); //C
cdSndData(0x52); //R
cdSndData(0x4F); //O
int main(void)
PLLFBD = 0x00A0;
CLKDIV = 0x0048;
unsigned char c;
int i;
//Init LCD Dispay
LCD_Reset();
LCD_Init();
ICD2
