driving an FET using PWM?
disenteako
Newbie level 3
pwm fet
Hi! I have a project which consists of a buck converter that needs to drive an NMOS or a PMOS using a PWM output from a microcontroller. The problem is the PWM output of the microcontroller has a 0V to 5V range which is not enough to properly turn on and off the FET given a FET Vin of 16V-20V. What FET driver or FET gate driver can you suggest to solve my problem? Thanks.
    disenteako
driving fet
Very nice. Thank you very much!!! : )
driving a fet
Follow up...
I'm having trouble making my buck converter work. I've already used this
After computing the inductor and capacitor values, I still can't get a decent output on my circuit using Multisim.
Basically, I just want to output 12 Volts given an input voltage of 20 Volts using a MOSFET in a buck converter. My FET works properly but the Voltage output after the inductor and capacitor values aren't. Any suggestions?
multisim pwm
posting a schematic might help..
but did you put a load resistor in parallel with your output capacitor? sometimes you need to pull a little current to get the thing working right. pick value based on simple equation:
R = Vout/Iout
make sure your current is appropriate for the size of your converter.
Mr.Cool
