RohanDey
Member level 2
- Joined
- Feb 17, 2013
- Messages
- 42
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- India
- Activity points
- 1,688
Hello,
I am trying to design a system where I need to drive a relay using a wireless signal. On one end there is a MCU board with a switch, when pressed will transmit a RF signal and the receiver will drive a relay upon receiving this signal.
I have developed the wireless Tx Rx part. Also, I have worked with 12VDC relays using relay drivers. Now my requirement is to drive a relay/contactor of heavy load, about 63A, 440V. This relay/contactor will be connected to a 3 phase motor.
The actual application is, when the mains are OFF (in case of a power cut), the motor will run on a generator. Currently the system works using manual change over switches placed near the motor, which are pushed after the generator is turned ON. The generator is 200 meter far from the motor, hence the RF signal.
Since I do not have any experience in driving heavy load relays, I am looking for some help, firstly in deciding the type of relay available in the market, to be used in driving such 3-phase loads. Since it is a 3-phase line I believe the relay will be 4PDT or 4xSPDT (for 3 phase and 1 neutral). Secondly, the process how such relays are to be driven using a micro controller. Thirdly, what are the necessary precautions to be taken in the circuit, while working in such loads.
Any kind of help is greatly appreciated. Thanks..
