DRC Settings for Altium - Net Class to Default nets
jayakrishnanj
Junior Member level 2
Chennai, India.
Hi Team,
I just started using Altium and facing the following issue
How can we set clearance rule for Bunch of net class to Default nets (Non net class)
Best regards,
Jayakrishnan J
In the PCB Rules window you can set the Scope of a net rule. If it's "All" then it applies to all nets (imagine that). If that rule is preceded by a rule that applies to a specific Net Class (or component, or whatever) then that rule takes precedence, and then the remaining nets get the "all" rule.
Thank you for your reply, If it's "All" net's, does it also include 'nets' in Net class's
--- Updated ---
Thank you
if there’s no rule for a specific net class, then it falls under the “all” rule
LaTeX Commands Quick-Menu:
