DRC license error cadence layout
bhav
Full Member level 2
Ahmedabad, India
cadence layout drc
i am unable to DRC on my layout .
It says No DRC or DRC License (312) is available.
I have checked my license file there is drc license available.
Please suggest something as i have not found anything which helps me out even on Cadence Sourcelink database.
This is output after i run the drc in layout.
license 312 in cadence for drc
Hi bhav,
It is really a license issue. You need to ask the help of your CAD support guys in your work.
Is this your first time running DRC in this layout?
Cheers
Are you trying to perform Diva or Assura DRC?
yes fixrouter4400
this is first time i am doing DRC
i am using NCSU Kit with DIVA rules file
Check if you have the appropriate license. From your screenshot it seems you need to check the 312 license
yes malizevzek
i have checked my site license there is no 312 item
but it has lines
FEATURE Assura_DRC cdslmd 3.1
# Product Id : 72110, [Version: 2.0]
# Product Name: Assura(TM) Design Rule Checker
# Product Type: Floating
# Feature: Assura_UI [Version: 3.100]
# Feature: Assura_DRC
this DRC License error comes when i run ic5141
the problem started this way----
when i try to invoke ic61 it gives error in starting the layout that could not get the license.
so i installed the older ic5141 an ddrawn my layout sucessfully but got stuck in the DRC license
From which menu are you trying to run DRC?
Does your design kit supprort ic61 version?
i am using the NCSU cdk kit
in tutorials on the web i found it working on ic61
so i tried ic61 but it gives error in starting the layout that it could not get the license. trying higher tiered license...
afterwards i installed the older ic5141 and drawn my layout sucessfully but got stuck in the DRC license.
in the image i have posted above the available license window show Diva DRC lic 71110. which is for assura drc in my license file.
so i gota confused which to run and tried both but it show drc license unavailable.
