Drawing Airbridge in MWO
Microwave123
Member level 2
I have been trying to construct an airbridge in MWO AXIEM EM simulator but I can't seem to figure it out. Does anyone know how this is done?
Thank you in advance !
Hello,
It is very easy to construct Air Bridge in Planar em simulator especially in AWR AXIEM em editor...
Just create the additional Air dielectric layer apart from the substrate layer & add the conductor metalization, & vias to connect the below metallization that completes the bridge structure...
---manju---
I did what you describe and was able to come up with the air bridge but the program is not meshing the air bridges. Is there some settings that needs to be changed?
Thank you!
Hello,
upload ur MWO file *.emp, will try to suggest the solution...
---manju---
