h_cet
Member level 4
hello;
I would like to draw antennas having sinus structure. this sinus structures' s period are 3mm, 5mm respectivelly... I can draw the sinus antenna having 5mm period. In spite of that, I can not draw the sinus antenna having 3mm period. Pictures is following below;
3mm
5mm
It can be understanble from pictures that 5mm does not have any problem, in spite of it, 3mm has a serious problem.... moreover when I want to make a simulation of 3mm sinus antenna, hfss produces error which is a mesh error during the simulation...
what can I do againist this kind of problem.... becasue I encountered a problem ismilar to this before...
I will be waiting for your response...
thank you very much....
be welll.......
3mm
5mm
be welll.......
