sina shekari
- Joined
- Nov 21, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 36
There are 4 SCR and 2 diode.
After drawing the output voltage I would be grateful if someone could calculate the Mean voltage.
this formula is for RMS...Hi Sina
In your case out put voltage ( average ) can be easily calculated by the formula : sqrt(1/T integral over Vm^2 sin wm^2 dt ) from zero up to the firing angel .
But of course i hope you know if the load is inductive then the firing angel would be affected and will be changed and calculation needs more patience .
Best Wishes
Goldsmith
can you drawing the output voltage?
