PRABAKARDEVA
Full Member level 2
Why some pins are used as open collector/drain in microcontrollers?
Why open drain is used in i2c?
Can anyone reply.pls...
This is called a wired-OR configuration. Only the LOW condition is an active output, where the open drain sink the signal to 0V.
This way there is no danger for a collision between HIGH and LOW, resulting in a short Circuit.
Reading the status there is also no problem With a logical collision, since the unit expecting a HIGH, will know there is a logical collision if it is reading a LOW, and stop it's transmission. This way the unit With the LOW will 'win' and no error is resulting in the transmission.
