walters
Advanced Member level 2
unsoldering ic
When im unsoldering parts ,removing IC chips,Transistors,switches with alot of pins . What can i do without damaging the boards>
1.) Any tips or techniques thats are good ? because mostly the traces or holes will lift up , its much harded removing parts from double sided PC boards , how can i make them come out easier because i only have one soldering iron on one side when it really needs Two soldering irons at the same time it seems right?
2.) Another problem i have is "solder" gets stuck inside the double track HOLE. Mostly its the trace/hole that is connected to ground. I use a solder sucking alot , it still doesn't get the solder out of the hole. I tried using a resistor lead and poking it though still doesn't get the solder out. What can i do to make double sided PC board solder out when its stuck inside the hole?
