Dot matrix Display @ scrolling problem
dhakeparag81
Full Member level 2
Full Member level 2
INDIA
hello there,
Last time i post about typecasting char array to store address in unsigned int.
Now my new problem is about same project. Due to facing difficulties about using pointer i converted my program little different way.
In my project i used 5x7 dot matrix displays, each row having 10 display and total rows are 6.
when i display 10 characters in each row at that time i didn't face a problem, but when i scrolling them that time only first and last(6) row working perfectly, in other rows at particular time some of displays getting blank.
I am trying to figure it out but didnt get result, hopping u will suggest me the correct way.
#include<p18f4520.h>
#include<delays.h>
#define CS1 LATCbits.LATC2  //Latching ic chip select
#define CS2 LATCbits.LATC1  //Latching ic chip select
#define CS3 LATCbits.LATC0  //Latching ic chip select
#define CS4 LATEbits.LATE2  //Latching ic chip select
#define CS5 LATEbits.LATE1  //Latching ic chip select
#define CS6 LATEbits.LATE0  //Latching ic chip select
#define CLK1 LATBbits.LATB5   //clock for shift register 74hc164
#define CLK2 LATBbits.LATB4   //clock for shift register 74hc164
#define CLK3 LATBbits.LATB3   //clock for shift register 74hc164
#define CLK4 LATBbits.LATB2   //clock for shift register 74hc164
#define CLK5 LATBbits.LATB1   //clock for shift register 74hc164
#define CLK6 LATBbits.LATB0   //clock for shift register 74hc164
#define SDATA1 LATCbits.LATC6   //Data for shift register
#define SDATA2 LATCbits.LATC7   //Data for shift register
#define SDATA3 LATDbits.LATD4   //Data for shift register
#define SDATA4 LATDbits.LATD5   //Data for shift register
#define SDATA5 LATDbits.LATD6   //Data for shift register
#define SDATA6 LATDbits.LATD7   //Data for shift register
#pragma idata name0
unsigned char str1[50]="J.T. MAHAJAN, C.O.E., FAIZPUR, DEPT. OF E&TC.   ";//46
unsigned char str2[60]="A.M. PATIL PROF. & H.O.D.  P.M. MAHAJAN ASSO. PROF.   ";//52
unsigned char str3[55]="S.V. PATIL  ASSO. PROF.  K.S. BHAGAT  ASSO. PROF.   ";//49
#pragma idata name7
unsigned char str4[73]="N.S. PATIL  ASS. PROF.  O.K. FIRKE ASS. PROF.  G.D. BONDE ASS. PROF.   ";//69
unsigned char str5[80]="R.D. CHAUDHARI ASS. PROF.  A.B. NEHETE ASS. PROF.  G.L. ATTERDE ASS. PROF.   ";//75
unsigned char str6[82]="S.R. PACHPANDE ASS. PROF.  Y.K. KIRANGE ASS. PROF.   R.C. BAKSHE ASS. PROF.  ";//75
#pragma idata name1
unsigned char alphabets[215]={0x04, 0x0A, 0x11, 0x11, 0x1F, 0x11, 0x11,		//A
							  0x0F, 0x11, 0x11, 0x0F, 0x11, 0x11, 0x0F,		//B
							  0x0E, 0x11, 0x01, 0x01, 0x01, 0x11, 0x0E,		//C
							  0x0F, 0x12, 0x12, 0x12, 0x12, 0x12, 0x0F,		//D
							  0x1F, 0x01, 0x01, 0x0F, 0x01, 0x01, 0x1F,		//E
							  0x1F, 0x01, 0x01, 0x07, 0x01, 0x01, 0x01,		//F
							  0x0E, 0x11, 0x01, 0x1D, 0x11, 0x11, 0x0E,		//G
							  0x11, 0x11, 0x11, 0x1F, 0x11, 0x11, 0x11,		//H
							  0x0E, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0E,		//I
							  0x1C, 0x08, 0x08, 0x08, 0x08, 0x09, 0x06,		//J
							  0x11, 0x09, 0x05, 0x03, 0x05, 0x09, 0x11,		//K
							  0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x1F,		//L
							  0x11, 0x1B, 0x15, 0x15, 0x11, 0x11, 0x11,		//M
							  0x11, 0x13, 0x15, 0x19, 0x11, 0x11, 0x11,		//N
							  0x0E, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0E,		//O
							  0x0F, 0x11, 0x11, 0x0F, 0x01, 0x01, 0x01,		//P
							  0x0E, 0x11, 0x11, 0x11, 0x15, 0x09, 0x16,		//Q
							  0x0F, 0x11, 0x11, 0x0F, 0x05, 0x09, 0x11,		//R
							  0x0E, 0x11, 0x01, 0x0E, 0x10, 0x11, 0x0E,		//S
							  0x1F, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,		//T
							  0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0E,		//U
							  0x11, 0x11, 0x11, 0x0A, 0x0A, 0x04, 0x04,		//V
							  0x11, 0x11, 0x11, 0x15, 0x15, 0x1B, 0x11,		//W
							  0x11, 0x11, 0x0A, 0x04, 0x0A, 0x11, 0x11,		//X
							  0x11, 0x11, 0x0A, 0x04, 0x04, 0x04, 0x04,		//Y
							  0x1F, 0x10, 0x08, 0x04, 0x02, 0x01, 0x1F,		//Z
							  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,		//.
							  0x00, 0x00, 0x00, 0x00, 0x06, 0x06, 0x02, 	//,
							  0x02, 0x05, 0x05, 0x02, 0x15, 0x09, 0x16,		//&
							  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};	//
#pragma idata name2
unsigned char no_shift=0;
unsigned int k=0, j=0, i=0, jk=0, count=0,count2=0,count3=0,count4=0,count5=0,count6=0, shifting1=0,shifting2=0,shifting3=0,shifting4=0,shifting5=0,shifting6=0, temp1=0;
unsigned char shift_data=0;
#pragma udata name5
unsigned char first=0, second=0, third=0, fourth=0, fifth=0, sixth=0;//, *sixth_ptr=0;
unsigned char temp_no=0,*tmp=0;
#pragma udata name3
unsigned char temp_array[16]={0};
#pragma idata name4
void char_data_conv(unsigned char alpha);
void data_conversion(unsigned char data);
void nop(void);
unsigned char title_row(unsigned int num1);
unsigned char second_row(unsigned char num2);
unsigned char third_row(unsigned char num3);
unsigned char fourth_row(unsigned char num4);
unsigned char fifth_row(unsigned char num5);
unsigned char sixth_row(unsigned char num6);
#pragma code High_Vector_Section=0x08
void high_isr (void);
void High_Vector_Section (void)
	_asm goto high_isr _endasm
#pragma code
#pragma interrupt high_isr
void high_isr()
	if(INTCONbits.TMR0IF == 1)							// Timer0 causes interrupt.....?
	   										// Yes Then Execute Timer0 ISR.
	   INTCONbits.TMR0IF = 0;
void main (void)
//	OSCTUNE		= 0x80;									//INTSRC = 1.
//	OSCCON		= 0x76;									//IRCF2:IRCF0 = 1 i.e 8 MHz, I0FS = 1 Freq Is Stable, SCS1:SCS0 = 10 i.e Internal OSC Block.
	RCON		= 0xDF;									//IPEN = 1....
	INTCON		= 0xE0;									// GIE = 1, PEIE = 1, TMR0IE = 1.
	INTCON2		= 0x00;
	INTCON3		= 0x00;
	T0CON		= 0x88;									//TMR0ON = 1, PSA = 1.
	TMR0H		= 0xB1;									//Timer0 Registers.
	TMR0L		= 0xDF;
	ADCON1		= 0x0F;									//A/D OFF, Configure As Digital I/O Pin.
	CMCON		= 0x07;
	INTCONbits.INT0IF=0;
	INTCONbits.RBIF=0;
	TRISCbits.TRISC2=0;
	TRISCbits.TRISC5=0;
	TRISCbits.TRISC4=0;
	TRISCbits.TRISC1=0;
	TRISCbits.TRISC0=0;
	TRISCbits.TRISC3=0;
	TRISEbits.TRISE2=0;
	TRISEbits.TRISE1=0;
	TRISEbits.TRISE0=0;
	TRISBbits.TRISB5=0;
	TRISBbits.TRISB4=0;
	TRISBbits.TRISB3=0;
	TRISBbits.TRISB2=0;
	TRISBbits.TRISB1=0;
	TRISBbits.TRISB0=0;
	TRISCbits.TRISC6=0;
	TRISCbits.TRISC7=0;
	TRISDbits.TRISD4=0;
	TRISDbits.TRISD5=0;
	TRISDbits.TRISD6=0;
	TRISDbits.TRISD7=0;
	TRISDbits.TRISD0=0;
	TRISDbits.TRISD1=0;
	TRISDbits.TRISD3=0;
	TRISC=0;
	TRISD=0;
	TRISE=0;
	CS1=0;
	CS2=0;
	CS3=0;
	CS4=0;
	CS5=0;
	CS6=0;
first = 0;
second = 0;
third = 0;
fourth = 0;
fifth = 0;
sixth = 0;
	for(i=0;i<72;i++)
		DATA1=0;
		DATA2=0;
		DATA3=0;
		DATA4=0;
		DATA5=0;
		CS1=1;
		SDATA1=1;
		CLK1=0;
		CLK1=1;
		CLK1=0;
		CS1=0;
	SDATA1=0;
	while(1)
	//	first = title_row(first);
		second = second_row(second);
	//	second = second_row(second);
	//	third = third_row(third);
	//	fourth = fourth_row(fourth);
	//	fifth = fifth_row(fifth);
	//	sixth = sixth_row(sixth);
	first = num1;
	SDATA1=0;
	k=0;
		count++;
	if(count>30)
		count=0;
		shifting1 += 1;
	 for(no_shift = 0; no_shift<10; no_shift++)
		 jk=0;
		 char_data_conv(str1[num1]);
		 num1++;
		 if(num1 > 46)
			 num1 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting1;
			 temp1 = temp_array[k + 7];
			 temp1 = temp1 << (5 - shifting1);
			 shift_data = shift_data | temp1;
			 data_conversion(shift_data);
			CS1=1;
			CS1=0;
			 CLK1=0;
			 CLK1=1;
			 CLK1=0;
			 SDATA1=1;
			 if(no_shift==7)
				 CLK1=0;
		if(num1 > 46)
			 num1 = 0;
	 if(shifting1 >= 4)
		 first++;
		 shifting1 = 0;
	if(first > 46)
	 	 first = 0;
	 return first;
	second = num2;
	SDATA2=0;
	k=0;
	count2++;
	if(count2>80)
		count2=0;
		shifting2 += 1;
		 jk=0;
		 char_data_conv(str2[num2]);
		 num2++;
		 if(num2 > 52)
			 num2 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting2;
			 temp1 = temp1 << (5 - shifting2);
			CS2=1;
			CS2=0;
			 CLK2=0;
			 CLK2=1;
			 CLK2=0;
			 SDATA2=1;
		if(num2 > 52)
			 num2 = 0;
	 if(shifting2 >= 4)
		 second++;
		 shifting2 = 0;
	if(second > 52)
	 	 second = 0;
	 return second;
	third = num3;
	SDATA3=0;
	k=0;
	count3++;
	if(count3>80)
		count3=0;
		shifting3 += 1;
		 jk=0;
		 char_data_conv(str3[num3]);
		 num3++;
		 if(num3 > 50)		// Remaining for all check the array then confirm with 45
			 num3 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting3;
			 temp1 = temp1 << (5 - shifting3);
			CS3=1;
			CS3=0;
			 CLK3=0;
			 CLK3=1;
			 CLK3=0;
			 SDATA3=1;
		if(num3 > 50)
			 num3 = 0;
	 if(shifting3 >= 4)
		 third++;
		 shifting3 = 0;
	if(third > 50)
	 	 third = 0;
	 return third;
	fourth = num4;
	SDATA4=0;
	k=0;
	count4++;
	if(count4>80)
		count4=0;
		shifting4 += 1;
		 jk=0;
		 char_data_conv(str4[num4]);
		 num4++;
		 if(num4 > 70)
			num4 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting4;
			 temp1 = temp1 << (5 - shifting4);
			CS4=1;
			CS4=0;
			 CLK4=0;
			 CLK4=1;
			 CLK4=0;
			 SDATA4=1;
		if(num4 > 70)
			 num4 = 0;
	 if(shifting4 >= 4)
		 fourth++;
		 shifting4 = 0;
	if(fourth > 70)
	 	 fourth = 0;
	 return fourth;
	fifth = num5;
	SDATA5=0;
	k=0;
	count5++;
	if(count5>80)
		count5=0;
	//	shifting5 += 1;
		 jk=0;
		 char_data_conv(str5[num5]);
		 num5++;
		 if(num5 > 75)
			 num5 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting5;
			 temp1 = temp1 << (5 - shifting5);
			CS5=1;
			CS5=0;
			 CLK5=0;
			 CLK5=1;
			 CLK5=0;
			 SDATA5=1;
		if(num5 > 75)
			 num5 = 0;
	 if(shifting5 >= 4)
		 fifth++;
		 shifting5 = 0;
	if(fifth > 75)
	 	 fifth = 0;
	 return fifth;
	sixth = num6;
	SDATA6=0;
	k=0;
	count6++;
	if(count6>80)
		count6=0;
	//	shifting6 += 1;
		 jk=0;
		 char_data_conv(str6[num6]);
		 num6++;
		 if(num6 > 75)
			 num6 = 0;
		for(k=0;k<7;k++)
			 shift_data = temp_array[k] >> shifting6;
			 temp1 = temp1 << (5 - shifting6);
			CS6=1;
			CS6=0;
			 CLK6=0;
			 CLK6=1;
			 CLK6=0;
			 SDATA6=1;
		if(num6 > 75)
			 num6 = 0;
	 if(shifting6 >= 4)
		 sixth++;
		 shifting6 = 0;
	if(sixth > 75)
	 	 sixth = 0;
	 return sixth;
	switch(alpha)
		case 'A':
				temp_no =0;
				break;
		case 'B':
				temp_no = 7;
				break;
		case 'C':
				temp_no = 14;
				break;
		case 'D':
				temp_no = 21;
				break;
		case 'E':
				temp_no = 28;
				break;
		case 'F':
				temp_no = 35;
				break;
		case 'G':
				temp_no = 42;
				break;
		case 'H':
				temp_no = 49;
				break;
		case 'I':
				temp_no = 56;
				break;
		case 'J':
				temp_no = 63;
				break;
		case 'K':
				temp_no = 70;
				break;
		case 'L':
				temp_no = 77;
				break;
		case 'M':
				temp_no = 84;
				break;
		case 'N':
				temp_no = 91;
				break;
		case 'O':
				temp_no = 98;
				break;
		case 'P':
				temp_no = 105;
				break;
		case 'Q':
				temp_no = 112;
				break;
		case 'R':
				temp_no = 119;
				break;
		case 'S':
				temp_no = 126;
				break;
		case 'T':
				temp_no = 133;
				break;
		case 'U':
				temp_no = 140;
				break;
		case 'V':
				temp_no = 147;
				break;
		case 'W':
				temp_no = 154;
				break;
		case 'X':
					temp_no = 161;
				break;
		case 'Y':
				temp_no = 168;
				break;
		case 'Z':
				temp_no = 175;
				break;
		case '.':
				temp_no = 182;
				break;
		case ',':
				temp_no = 189;
				break;
		case '&':
				temp_no = 196;
				break;
		case ' ':
				temp_no = 203;
				break;
	for(j=0; j<7; j++)
		temp_array[jk] = alphabets[temp_no];
		temp_no++;
		jk++;
void nop(void)
	unsigned int i=0;
	for(i=5;i>0;i--);
void data_conversion(unsigned char data) //for latching ic 74hc373
	if(data & 0x01)
		LATCbits.LATC3=1;
	else
		LATCbits.LATC3=0;
	if(data & 0x02)
		LATDbits.LATD0=1;
	else
		LATDbits.LATD0=0;
	if(data & 0x04)
		LATDbits.LATD1=1;
	else
		LATDbits.LATD1=0;
	if(data & 0x08)
		LATCbits.LATC5=1;
	else
		LATCbits.LATC5=0;
	if(data & 0x10)
		LATCbits.LATC4=1;
	else
		LATCbits.LATC4=0;
My concept of the project is provide +5v through latching ic and GND through shift register to display.
