Your circuit uses pin 1 of the opamp as its output, not pin 7.donrigor said:How do i make a pulse of 5 Volts making the ouput at pin 7 a 5 Volts instead of 3.5 volts?
Varying R8 to extreme left and extreme right doesn't produce a 5 volts at pin 7.
Not very. They have effective ESD protection. It's O.K. to use 74LS, but 74HC is a good replacement. CD400X devices are particularly suited for slow logic circuits, less sensitive to interferences, and they have a comfortable supply voltage range.I have read that CMOS is very sensitive.
