does the following two codes in VHDL mean same. What is difference in implementaion
FixitFast
Junior Member level 2
Hello every one.
The two codes are below
if(valid_shift_HIGH = '1') then
if(buff_2Sn_empty = '0' and buff_2Sn_1_empty = '0') then
 rden_buff2 <= '1';
 else
 rden_buff2 <= '0';
 end if;
 else
  rden_buff2 <= '0';
  end if;
the other is
rden_buff2 <= valid_shift_HIGH and (not buff_2Sn_empty and not buff_2Sn_1_empty);
I suppose the final implementaion + logical operation for both should be exactly same ?
Any idea?
hi
well the logical operation for both would be same. However implementation at hardware level will be slightly different, but it does not matter much (in my opinion) since at the end of the day the results are what you want
Why not compile them both and see the differences for yourself in the RTL and implementation diagrams?
Good suggestion. Nevertheless can it be derived from language specification that both hardware implementations are exactly identical.
