Do u mean the crystal/oscillator? I might use a 4MHz or 8MHz one!djalli said:What is the frequency (or range of frequencies) you will be operating? Then I tell you the values of caps you need.
ericmar said:Do u mean the crystal/oscillator? I might use a 4MHz or 8MHz one!djalli said:What is the frequency (or range of frequencies) you will be operating? Then I tell you the values of caps you need.
Yes. But how do I know wat frequency my circuit will be operating?djalli said:ericmar said:Do u mean the crystal/oscillator? I might use a 4MHz or 8MHz one!djalli said:What is the frequency (or range of frequencies) you will be operating? Then I tell you the values of caps you need.
You need to put by-pass capacitors under the IC's is that what you want?
pixel said:My advice is not to spare on capacitors.
