Do polysilicon resistor have flicker noise?
776ft
Newbie level 6
resistor low frequency noise
How to characterize the flicker noise of polysilicon resistor?
are there any papers or books I can turn to?
flicker noise resistor
Yes they do,
Here few papers that may be of help.
[1] S.L.Jang, "A model of I/f noise in polysilicon resistors", Solid-State Electronics, Vo1.33, No.9, pp.1155-1162, 1990.
[2]O.Roux dit Buisson and G. Monn, "Flicker Noise Characterization of Polysilicon Resistors in Submicron CMOS Technologies", in proceedings of IEEE 1997 Int. Conference on Microelectronics Test Structures, Vol 10, March 1997.
[3]K.M. Chen, G.W. Huang, D.Y. Chiu, H.J. Huang and C.Y. Chang," Analysis of low-frequency noise in boron-doped polycrystalline silicon germanium resistors", Appl Phys Lett 81 (14) (2002), pp. 2578-2580.
[4]Brederlow, R.; Weber, W.; Dahl, C.; Schmitt-Landsiedel, D.; Thewes, R., "Low-frequency noise of integrated polysilicon resistors," Electron Devices, IEEE Transactions on , vol.48, no.6, pp.1180-1187, Jun 2001
A book that may give u some help is
Electronic noise and interfering signals By Gabriel Vasilescu, Published by Springer, 2005
Btw modern simulators do simulate flicker noise, they may have a model for poly silicon resistors that will reference to some book or paper they use..thats a good point to start also.
poly resistor 1/f noise
Thanks Soben,
I saw their expression for flick noise of a resistor is
Vn²=Vbias²×0.5×10e9/(WLf)
which Vbias is the voltage difference across the resistor, W and L is the dimension parameter of the resistor, is that right?
Yes they do,
resistor flicker noise
Yes that is correct.
Sorry for the late reply
