Dear Sir,
I have designed low noise amplifier at 1.3GHz using linear Avago ATF 54143 microwave transistor, have measured the gain as 16dB , noise figure as 0.70 dB ,input and output return loss as -11dB, and stability as 1.4130. What is my doubt is , do I require to measure the IIP2, IIP3, P1dB, IMD3 , and power dissipation of low noise amplifier at 1.3 GHz.Any how Avago ATF54143 transistor used that is linear transistor.I have read lot of IEEE papers regarding on low noise amplifier design, most of them used the CMOS transistors and they have measured IIP2, IIP3 , IMD3,P1dB compression point, and power disipation.What is my quesition is,do I require to measure IIP2, IIP3, IMD3, P1dB, and power disipation for my designed low noise amplifier at 1.3 GHz using ATF54143 transistor. I designed using the software AWR MWO, can you help me anybody.
