hi
these days i m trying to learn programming in assembly language for 80196. but i m facing a lot of problems. i m using IAR workbench tool. i want to know is it nessecary to know C or C++ to learn programming for 16 bit microcontroller.
i have worked on 8051 before.
pls help me
thanx
196 ?? wow log time no see .... Listen the more complex the processor the higher level of language you need to be efficient .This days the cpus are very fast so you can accept a lot of not optimazed code traded by instead a quick development .Who cares how fast you can turn on a LED . So sooner or later you will have to go C .Why not start now .And be more efficient overall .
The best way to learn 80196 programming very quickly and efficiently is using an Emulator.There are lots of ICEs(in circuit emulator)on the web the famous one is project 96 you can find here www.phyton.com/htdocs/downloads.shtml or you can implement yor own trainer yourself .There are also lots of simulators on the web.
