DIY Moving Message Display
circuit diagram of 48 x 8 led scrolling message
The 74HC154 would work well as the column driver (16)
The 74HC164 would work as the row driver (80)
You may be able to run the row without drivers at 10ma each with a 74ALS164 but you'll need PNP drivers possibly darlingtons on the columns.
moving message display system
hello blueroomelectronics
sorry u misunderstand that not 16 cols 80 rows actually that is 16 rows 80 columns
16x80
so far i am giving cols from 164 and rows directly from portb its working fine 8x32(8 rows and 32 cols) now i want to expand this with (16x80 16 rows 80 columns)
if u have any idea can u tell me plsss
thank u
moving message display with keyboard
thank u
Neo,
Are you still using anode rows and cathode columns?
moving message sign project
yes
i putted 1 bc547 tr for cols to make cathode
how to make led moving message display
I up a file form web.
dawn simulator led diy
Hi All,
I'm new this forum's member. I have read much your posts and I'm very interesting on DIY moving message display.But I'm novice, please advise me some books guide to design led display especially giant outdoor led screen.I tried to search much times but found nothing.
Thankyou advance.
moving message sign circuit
hello tammc
i am also want to do the same to design moving message for 16x40 but not get any help from here
pic16f877 matrix 16x80
hi all....
do anyone have the moving message display schematic diagram and program that build up by PIC16F877 or any PIC µC...can post it up....pls.....
thanks..........
wireless moving message display circuit
thnks for the posts..
how we can move up-down then message .
sorry for my english
software download led moving message sign
agreed..
actually im doing this at the moment
but im using 16x2
Al Farouk said:
Dear saif
I think that I understand what you need. The idea os the design of the moving message as follows
The shape of the characters are saved in EPROM (for example) and the display matrix are arranged in row and columns each column can be enabled individually.
Counters are used to address the contents of the EPROM in synchrounous with the columns enabled sequence so the shape of the character can be drwan on the Matrix.
to show the moving effect, enable column n then n-1 then n-2 and display the output of the EPROM content on the appropreiat column, repeat this action for example 25 --> 50 time/second.
repeat the last setp by shifting the columns address i.e enable n+1 then n then n-1 and so on.
repeat the last step till the end of your dislay matrix, you get the moving effect.
regards
moving message display pcb +layout
I need something to Atmel AVR, I just find for PICs...
pcat (ps2) keyboard with moving message
Here is my 8051 basd moving message circuit, codes & proteus design
another with pc controlled
moving message sign software downloadable
Hello sohail_akram
i downloaded your sign project and the schematics of the one with 24c64 does not match your code or are you deveoping it ,and during stimulation it does not run smoothly what compiler did you use.
moving dot matrix display gif
Hello Akram
i downloaded ur project its good as i am developing the same led moving message 8x80 and 16x80 for start i am designing 8x80 using pic16f877a and 74hc595
can i use ur code in this if u have any info doing in pic16f877a pls can u tell me i am using mikroc and ccs c i am new
thank u very much
pcb layout for moving message display crcuit
hi, everyone
I am new in edaboard. I searched all of the topic. I am interested in 8051 and C and I couldn't find any running good project. I want a project using 8051 with 7x20 led matrix. anyone help me please
regards
microcontroller based scrolling message software
Anyone knows if i can implement a led dislpay using PIC controller which i can change the text if i wanted to without having to reprogram it? is it possible to implement? the examples i saw so far in the very first few page (quick glance, not thorough) didnt mention anything about it.
What i mean is that my controller will of course be connected to my PC, from my pc, i decide what i display on the LEDs. I can change the intended message from
my computer and the display led will change instantaneously.
This is to help in making announcement....
thanks!
multiplex led matrix 7x40
Hello eugenesiew
I am also trying to desing the same LED Moving message Displays so far i tried to do 8x24 Using PIC16F877A and 74HC595 ,ULN24C02 till now i am saving the data from usart to 24C02 EEProm
what i am looking is to develop the software through visual basic to sotre the fonts patterns then display on the led moving message this my idea
i seen many form in this site but none will be useful
so tried my self so far succeded hope i will get this work soon and i will post the schematics and source
i am using mikroc compiler
hope for the best
if u have any questions reply me of mail ishqboy2006@yahoo.com how much i know i will help u
thanks
cd4094 tutorial cours
NeoMatrix, I see you are still floundering both logically and electrically. After all that help in the other forums, and for so long now... :cry: I am surprised that you haven't paid attention in these forums because I came across an Elektor Magazine article posted (like this very thread) with a circuit and code, just for someone like yourself who doesn't get it yet.
Don't overcomplicate a simple concept. The 16F877A has plenty of ROM to store all your fonts and custom characters. Depending on your configuration you can use font tables created for LCD's (HD44780) or GLCD's (KS0108). These can be found everywhere, with the GLCD configuration being the most resourceful as far as memory is concerned. You can also create your own characters with a free font creator of some sort. Simply call them as needed through USART and display them... with some sort of algorithm that fits your layout.
cofmaker examples
I have to agree with xorcise, you need to have a grasp of driving such a large amount of LEDs. It's one thing to drive a small matrix of LEDs but quite another to drive 16x80 or 16x40
These are large power hungry displays, to get any brightness out of those LEDs you're going to have to drive them at about 50ma each. So a typical row of 80 will require 50ma x 80 LEDs = 4Amps of current. The PIC can neither sink or source this amount of current without drivers.
