DIVIDE A CLOCK BY 2.5
meetspraveen
Member level 2
divide clock by 2.5
CAN ANYONE TELL ME HOW TO DIVIDE CLOCK BY 2.5 using digital circuits?e.g FF etc
Design a circuit which can work on both edges of clock.
TAke a counter which works on both edges.........
it should be a mod 5 counter.........
clock 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1
count 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1
o/p 0 1 1 0 0 0 1 1 0 0 0 1 1 0 0 0 1
Now...............U please post the design ................it would be better if you share your answer.......
There is a document by name CLOCK DIVIDERS MADE EASY here itself in this sub-forum...........
it has a lot os clock dividers and you can easily understand so.........
all the best.............
see this
  • clock_dividers_made_easy_7789.pdf
hi,
i have a question here,
what is the a circuit have 50% duty cycle? it is could be others duty cycle like 40% @ 100%?
any explanation will be much appreciate!
hairo
hairo said:
hi,
hairo
Please post your query Clearly.
When you divide by real numbers like 2.5, the duty cycle will not be 50%.
