Where are you located?bingoz2002 said:i need help in writing the source code to display time/clock on the LCD using PIC16F877. Can anyone provide me with the help??? pls.. the program i'm using is MPLAB. HELP!!!
I can send you my ASM code and a schematic if you want.bingoz2002 said:i'm located in Singapore.. actually i'm quite a newbie in this stuffs and i am required to display time on LCD for my MAjor Project. The programming language i'm advised to use by my supervisor is Assembly language (MPLAB). I'm quite stuck at the source code for displaying real time clock. However, i've quite done the initialisation part. HELP!!
I have the code for a 2x20 and a 2x16 LCD, which one do you prefer?
Can you give me an email address where to sent it?
I recommend the DS1307 from Maxim (you can ask a free sample!).bingoz2002 said:which RTC IC would u recommend me to use n do i need to have a separate program to set the time to the IC? And do i connect the RTC IC to the same PIC as the LCD??i'm a little confused here about the connections.
