shadow15
Newbie level 3
Hello, I want to display a simple text on my SC204A LCD using my PIC16F877A. The compiler I am using is mikro C PRO version 6.0.0. There are no errors when I build my code but I still have no output on my LCD. Here is my code
Is there a problem with my code? I can't figure out the problem. Kindly help me Thanks!
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
char txt1[] = "This is a Test";
char txt2[] = "Thank you";
void main()
PORTB = 0x00;
TRISB = 0x00; // set direction to be output
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Cmd(_LCD_TURN_ON);
Lcd_Out(1,1,txt1); // Write text in first display
Delay_ms(500);
Lcd_Out(1,1,txt2); // Write text in next display
Delay_ms(500);
