Displaying data on LED SEGMENT
nayakajit87
Member level 5
I am using PIC16F886 4mhz crystal Timer1 interrupt with 1ms . i am trying to build timer application.
When top display == bottom display the process should stop. Top display Set value Bottom Display shows process value.
Top display set usually in time format if value 0210 means if LED_SS==0 02Sec 10ms LED_MS==0 02Min 10S LED_HM==0 02H 10Min
I would like to replace Dissect_2 function since currently i am passing argument as integer. So display update as whole integer but i am looking for function it update digit by digit.
I am looking for C function so that if my Sec paramter reaches 59s the update value should be 1min ,59s should start update again in 0. when it reaches 59S it should update 1m-2M the process continue tell it reaches 2M 10S in below code Tpvalue=0210 means bottom display will stop at 0210
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
#include <htc.h>
#include <stdio.h>
#include <math.h>
#include "delay.h"
#define _XTAL_FREQ 4000000
__CONFIG(FOSC_HS & WDTE_ON& PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF  & DEBUG_OFF&MCLRE_ON &BOREN_ON&FCMEN_ON &WRT_OFF);
#define RLY_DRV1     RB4
#define PRG_EN       RA4
#define DISPCLK         RB5
#define DISPDATA        RB6
#define STROBE          RB7
#define RESET           RB1
unsigned char Main_Flag=0;
unsigned char j=0;
unsigned int Bottom_Value=0;
unsigned int Top_Display=1234;
struct {
    unsigned RUNMODE                :1;
    unsigned PRGMODE                :1;
    unsigned KeyLock_RESET1         :1;
    unsigned KeyLock_SELECT1        :1;
    unsigned KeyLock_ADVANCE        :1;
    unsigned BLINKFLAG              :1;
    unsigned BLINKFLAG1             :1;
    unsigned FLASHFLAG              :1;
    unsigned KeyTEST_PRESS          :1;
    unsigned MANUAL_RESET           :1;
    unsigned AUTO_RESET             :1;
} bits;
unsigned char Dec_pt=1;
unsigned char SETPRESS=0;
unsigned char DgtSel=2;
unsigned int Debounce=0;
unsigned char LEDBuffer_1[8];
unsigned int Hour,Min,Sec,Msec;
unsigned char Counter=0;
unsigned char Digit[4] = {0,0,0,0};
const unsigned char DISPTABLE[28] = {0x03,0x9F,0x25,0x0D,0x99,0x49,0x41,0x1F,0x01,0x09,0x11,0x83,0x31,
                                     //0  //1  //2  //3  //4  //5  //6  //7  //8  //9  //A  //U  //P
                                     0xD1,0xE3,0x89,0x63,0xE1,0xF5,0xC1,0x61,0x71,0xF3,0xFD,0xD5,0x85,0xFF,0X43
//h  //L  //Y  //C  //t  //r  //b   //E //F  //I  //-  //n //d  //blank //G
unsigned int  OVOL=105;
unsigned char UVOL=75,UCRT=30;
unsigned char Sub_Pulse=1;
unsigned char Sub_Time=1;
unsigned char Sub_Relay=1;
unsigned char Sub_HMS=1;
unsigned char voltage=0;
unsigned char DecimalTOP=0;
unsigned char BLINKSEGMENT=0;
unsigned char BLINKCOUNT=0;
unsigned char BLINKFLAG=0;
unsigned char i=0;
unsigned char k=0;
unsigned char l=0;
unsigned char m=0;
unsigned char BLINKCOUNT1=0;
unsigned char BLINKCOUNT2=0;
unsigned char BLINKCOUNT3=0;
unsigned char BLINKCOUNT4=0;
unsigned char Blink_Count=1;
unsigned char Converted_Value;
unsigned int Top_Value=0;
unsigned char EEPROM_Write_Flag=0;
unsigned char EEPROM_Read_Flag=1;
unsigned int Result;
//              Sub Menu Change
void SubMenu(unsigned char Chr5, unsigned char Chr6, unsigned char Chr7,
             unsigned char Chr8)
  LEDBuffer_1[0] = DISPTABLE[Chr5];
  LEDBuffer_1[1] = DISPTABLE[Chr6];
  LEDBuffer_1[2] = DISPTABLE[Chr7];
  LEDBuffer_1[3] =  DISPTABLE[Chr8];
//              Main Menu Change
void Main_Menu(unsigned char Chr1, unsigned char Chr2, unsigned char Chr3,
               unsigned char Chr4)
  LEDBuffer_1[4] = DISPTABLE[Chr1];
  LEDBuffer_1[5] = DISPTABLE[Chr2];
  LEDBuffer_1[6] = DISPTABLE[Chr3];
  LEDBuffer_1[7] = DISPTABLE[Chr4];
// Whole number broken into individual digits and converted to its LED 7 segment value.
// Called from timer interrupt.
void Dissect(unsigned int Value) {      // Spliting of process value in digits form
    unsigned char a,Temp;
    for(a = 8; a >= 5 ; a--) {
        Temp = Value%10;
        Value = Value/10;
        LEDBuffer_1[a-1] = DISPTABLE[Temp];
// called outside timer interrupt.
void Dissect_2(unsigned int Value) {            // Spliting of process value in digits form
    for(a = 4; a >= 1 ; a--) {
        Temp = Value%10;
        Value = Value/10;
// Serially transmitt display data.
void ShiftData(unsigned char Data) {
    unsigned char i;
    STROBE = 0;
    DISPCLK = 0;
    DISPDATA = 0;
    for(i = 0; i < 8; i++) {
        if(Data & 0x01) DISPDATA = 1;
        else DISPDATA = 0;
        DISPCLK = 1;
        asm("nop");
        asm("nop");
        DISPCLK = 0;
        Data = Data >> 1;
    asm("nop");
    asm("nop");
    STROBE = 0;
    DISPCLK = 0;
    DISPDATA = 0;
//                          Enable strobe after data transmission
void EnableStrobe() {
    STROBE = 1;
    asm("nop");
    asm("nop");
    STROBE = 0;
    DISPCLK = 0;
    DISPDATA = 0;
//                              Display Driving Routine
void Display() {
    switch(DgtSel) {
        case 1:
            ShiftData(LEDBuffer_1[4]);                  //display changed for dold
            ShiftData(0x80);
            EnableStrobe();
            DgtSel = 2;
            break;
        case 2:
            ShiftData(LEDBuffer_1[5]);
            ShiftData(0x40);
            EnableStrobe();
            DgtSel = 3;
            break;
        case 3:
            ShiftData(LEDBuffer_1[6]);
            ShiftData(0x20);
            EnableStrobe();
            DgtSel = 4;
            break;
        case 4:
            Dec_pt=0;
            ShiftData(LEDBuffer_1[7]);
            ShiftData(0x10);
            EnableStrobe();
            DgtSel = 5;
            break;
        case 5:
            ShiftData(LEDBuffer_1[0]);
            ShiftData(0x08);
            EnableStrobe();
            DgtSel = 6;
            break;
        case 6:
            ShiftData(LEDBuffer_1[1]);
            ShiftData(0x04);
            EnableStrobe();
            DgtSel = 7;
            break;
        case 7:
            ShiftData(LEDBuffer_1[2]);
            ShiftData(0x02);
            EnableStrobe();
            DgtSel = 8;
            break;
        case 8:
            ShiftData(LEDBuffer_1[3]);
            ShiftData(0x01);
            EnableStrobe();
            DgtSel = 1;
            break;
        default:
            break;
    if(Blink_Count==1) {
        Dec_pt=1;
        //LEDBuffer_1[1]=LEDBuffer_1[1]&0X01;
        if(BLINKFLAG == 1 && DgtSel == BLINKSEGMENT) {
            BLINKCOUNT1++;
            if( BLINKCOUNT1>20)
                LEDBuffer_1[0] = DISPTABLE[26];
            BLINKCOUNT1++;
            if(BLINKCOUNT1==50) {
                BLINKCOUNT1=0;
                LEDBuffer_1[0] = DISPTABLE[j];
    if(Blink_Count==2) {
            BLINKCOUNT2++;
            if( BLINKCOUNT2>20)
                LEDBuffer_1[1] = DISPTABLE[26];
            BLINKCOUNT2++;
            if(BLINKCOUNT2==50) {
                BLINKCOUNT2=0;
                LEDBuffer_1[1] = DISPTABLE[k];
    if(Blink_Count==3) {
        Dec_pt=1;
            BLINKCOUNT3++;
            if( BLINKCOUNT3>20)
                LEDBuffer_1[2] = DISPTABLE[26];
            BLINKCOUNT3++;
            if(BLINKCOUNT3==50) {
                BLINKCOUNT3=0;
                LEDBuffer_1[2] = DISPTABLE[l];
    if(Blink_Count==4) {
            BLINKCOUNT4++;
            if( BLINKCOUNT4>20)
                LEDBuffer_1[3] = DISPTABLE[26];
            BLINKCOUNT4++;
            if(BLINKCOUNT4==50) {
                BLINKCOUNT4=0;
                LEDBuffer_1[3] = DISPTABLE[m];
//// RUN_RESET FUNCTION
void PRG_RUN_RESET() {
    Bottom_Value=0;
//// RESET KEY pressed
void Key_CHK_RESET() {
    if(!RESET && !bits.KeyLock_RESET1) {        // CHECK IF SELECT IS PRESSED
        Debounce++;
        if(Debounce > 10) {
            Debounce = 0;
            bits.KeyLock_RESET1 = 1;
            PRG_RUN_RESET();
    } else if(RESET && bits.KeyLock_RESET1) {
        bits.KeyLock_RESET1 = 0;
        Debounce = 0;
//                              Timer Interrupt - 5mSec
void interrupt isr(void) {
    asm("clrwdt");
    if (TMR1IF) {
        TMR1IF = 0;
        //  TMR1H = 0x3C;
        //  TMR1L = 0xB0;100ms
        TMR1H = 0xFE;
        TMR1L = 0x0C;// timer interrupt for 1ms
        if(Top_Display>Bottom_Value) {
            Bottom_Value++;
        } else if(Top_Display==Bottom_Value) {
        Display();
//                              Main program starts here.
void main(void) {
    unsigned char value;
    unsigned char conter = 0;
    InitController();
    while(1) {
        if(PRG_EN==1) {
            if(Main_Flag==1) {
                Main_Menu(5,17,18,17);
                if(Sub_Pulse==1) {
                    SubMenu(12,14,5,20);
                } else if(Sub_Pulse==2) {
                    SubMenu(16,0,24,17);
                } else if(Sub_Pulse==3) {
                    SubMenu(24,0,5,17);
                } else {
                    Sub_Pulse=0;
            Main_Flag=0;
            Process_PRG_MODE();
        } else {
            Main_Flag=1;
            Process_RUN_MODE();
// InitController
void InitController() {
    PORTA    = 0b00000000;
    TRISA    = 0b00111000;
    TRISB =0b00001111;
    PORTB = 0b00000000;
    TRISC = 0X00;
    PORTC = 0b00000000;
    WREN=0;
    WDTCON = 0b00010111;
    INTEDG = 0; //falling edge
    INTF = 0;
    INTE = 1;
    WPUB    = 0b00000000;
    ANSEL  = 0b00000000;
    ADCON0  = 0b00000000;
    ANSELH = 0b00000000;
    ADDEN  = 0;
    PIE1=0b00000001;
    PIR1=0x01;
    INTCON = 0xC0;
    T1CON=0X11;
    TMR1IE = 1;
    PEIE   = 1;
    GIE    = 1;
    LED_SS=0;
//RUN mode Selection
void Process_RUN_MODE() {
//Display_Faults(12,18,27,26,18,11,24,26);
    if(EEPROM_Read_Flag==1) {
        READ_EPROM();
        EEPROM_Read_Flag=0;
    Key_CHK_RESET();
    if(LED_SS==0) {
        Dissect(Top_Display);
        Dissect_2(Bottom_Value);
    } else if(LED_MS==0) {
    } else if (LED_HM==0) {
