a.sparrow
Newbie level 1
- Joined
- Apr 21, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,292
Hi everyone,
I am a newbie programmer and I am hoping that someone could guide me on the right path to completing this project.
I am using a PIC24HJ64GP502 chip to display the current temperature on an 20X4 I2C LCD screen. The temperature sensor I am using is a DS18B20 and I will be using a 5V power supply with a 4.7k ohm resistor. I am having trouble on how to approach this project. So far, I have used functions found in the libraries from the sensor and the lcd to print out the temperature. I have not run this on the actual board yet. I am not sure if the configuration part of the lcd is correct. I got it from a sample code project from the LCD's website. If anyone could help me find a tutorial on I2C initialization/configuration that would be helpful. I want to know if by using these functions, will I be able to print it onto the LCD.
Also, do I need to convert the temperature values into characters, in order to see it on the screen? I saw that implementation and I am not sure if it is necessary. Thank you in advance!
#include<OneWire.h>
#include<DallasTemperature.h> // temperature sensor
#include<LiquidCrystal_I2C.h> // lcd screen
// Data wire is plugged into pin 4 on the Pic
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
int DS18S20_Pin = 4; //DS18S20 Signal pin on analog 2 (pin4)
OneWire ds(DS18S20_Pin);
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
// Need to use the above url to determine the address of our 1-Wire temp sensor! Below has incorrect addresses.
DeviceAddress insideThermometer = { 0x28, 0x94, 0xE2, 0xDF, 0x02, 0x00, 0x00, 0xFE };
#define BACKLIGHT_PIN 13 [COLOR="#FF0000"]// I am only using VCC, GND, SCL, and SDA pins. Should I be using other pins as well? [/COLOR]
LiquidCrystal_I2C lcd(0x38); // Set the LCD I2C address
//LiquidCrystal_I2C lcd(0x38, BACKLIGHT_PIN, POSITIVE); // Set the LCD I2C address
// Creat a set of new characters
const uint8_t charBitmap[][8] = {
{ 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
{ 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
{ 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
{ 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
{ 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
{ 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
{ 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
{ 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
void setup(void)
//pinMode(backLight, OUTPUT);
//digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
lcd.begin(20, 4); // rows, columns for a 20x4 LCD
lcd.clear(); // start with a blank screen
lcd.setCursor(0,0); // set cursor to column 0, row 0 (upper left hand corner)
Serial.begin(9600); // start serial port
Serial.println("DS18B20 Demo");
sensors.begin();
sensors.setResolution(insideThermometer, 10); //sensor precision is 10 bits (can be 9,10,11,or 12 bits)
delay(2000);
lcd.print("Requesting temperature...");
sensors.requestTemperatures(); // command to get the temperatures
lcd.print("COMPLETE");
void loop(void)
//Print the temperature
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Current Temperature is: ");
lcd.setCursor(0,1); // set cursor at the second row on the lcd.
lcd.print(sensors.getTempC(0));
lcd.print(" °C "); // there will be a small space between the two temperature readings
lcd.print(sensors.getTempF(0));
lcd.print(" °F");
delay(1000);
