nyemba
Newbie level 1
- Joined
- Mar 6, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Dar es Salaam , Tanzania
- Activity points
- 15
Hello guys,
I have design a system that will receive text and display on the lcd but I dont know how can I receive that text, my thought is to use virtual terminal to insert the text that want to send by typing on he virtual terminal screen but when I type any character on the there is no any response. Below are my code:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 */ // LCD module connections sbit LCD_RS at RB4_bit; sbit LCD_EN at RB5_bit; sbit LCD_D4 at RB0_bit; sbit LCD_D5 at RB1_bit; sbit LCD_D6 at RB2_bit; sbit LCD_D7 at RB3_bit; sbit LCD_RS_Direction at TRISB4_bit; sbit LCD_EN_Direction at TRISB5_bit; sbit LCD_D4_Direction at TRISB0_bit; sbit LCD_D5_Direction at TRISB1_bit; sbit LCD_D6_Direction at TRISB2_bit; sbit LCD_D7_Direction at TRISB3_bit; // End LCD module connections int x; char txt[16]; //GSM Modem setup void GSM_Init(void); void GSM_Send(void); void GSM_Receive(void); void forward(){ Uart1_Init(9600); delay_ms(100); UART1_Write_Text("AT\r"); UART_Write(0x0D); delay_ms(100); UART1_Write_Text("AT+CMGF=1\r"); UART_Write(0x0D); delay_ms(100); UART1_Write_Text("AT+CMGR=1"); UART_Write(0x0D); delay_ms(100); delay_ms(100); txt[16] = UART1_Read(); UART_Write(0x0A); UART_Write(26); delay_ms(100); } void main(){ ADCON1 = 0X07; TRISB = 0; TRISD = 0; TRISC = 0X80; Lcd_Init(); Lcd_Cmd(_Lcd_Clear); while(1){ forward(); if (UART1_Data_Ready()) { // If data is received, Lcd_Out(1,1,txt); Lcd_out(2,1,"GSM"); } } }
