Re: display a word on the "Virtex 4" display(eg: V
thanks for your help.
please do you have better idee?
i habe one eg.but it don't work mit my Virtex-4 LC system board.
Added after 5 minutes:
i have lcd initialisation.Nown i want to write(VHDL) on the LCD.
thanks.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY lcd_controller IS
PORT(
clk : IN STD_LOGIC; --system clock
reset_n : IN STD_LOGIC; --active low reinitializes lcd
lcd_enable : IN STD_LOGIC; --latches data into lcd controller
lcd_bus : IN STD_LOGIC_VECTOR(9 DOWNTO 0); --data and control signals
busy : OUT STD_LOGIC; --lcd controller busy/idle feedback
rw, rs, e : OUT STD_LOGIC; --read/write, setup/data, and enable signals for lcd
lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); --data signals for lcd
END lcd_controller;
ARCHITECTURE controller OF lcd_controller IS
TYPE CONTROL IS(power_up, initialize, ready, send_data);
SIGNAL state : CONTROL;
BEGIN
PROCESS(clk)
VARIABLE clk_count : INTEGER RANGE 0 TO 2500000; --clock event counter for timing
BEGIN
IF(clk'EVENT and clk = '1') THEN
CASE state IS
--wait 50 ms to ensure Vdd has risen and required LCD wait is met
WHEN power_up =>
busy <= '1';
IF(clk_count < 2500000) THEN --wait 50 ms
clk_count := clk_count + 1;
state <= power_up;
ELSE
clk_count := 0;
rs <= '0';
rw <= '0';
lcd_data <= "00110000";
state <= initialize;
END IF;
--cycle through initialization sequence
WHEN initialize =>
busy <= '1';
IF(clk_count < 500) THEN --function set
lcd_data <= "00111100";
e <= '1';
ELSIF(clk_count < 3000) THEN --wait 50 us
lcd_data <= "00000000";
e <= '0';
ELSIF(clk_count < 3500) THEN --display on/off control
lcd_data <= "00001100";
e <= '1';
ELSIF(clk_count < 6000) THEN --wait 50 us
e <= '0';
ELSIF(clk_count < 6500) THEN --display clear
lcd_data <= "00000001";
e <= '1';
ELSIF(clk_count < 106500) THEN --wait 2 ms
e <= '0';
ELSIF(clk_count < 107000) THEN --entry mode set
lcd_data <= "00000110";
e <= '1';
ELSIF(clk_count < 110000) THEN --wait 60 us
e <= '0';
ELSE
clk_count := 0;
busy <= '0';
state <= ready;
END IF;
--wait for the enable signal and then latch in the instruction
WHEN ready =>
IF(lcd_enable = '1') THEN
busy <= '1';
rs <= lcd_bus(9);
rw <= lcd_bus(8);
lcd_data <= lcd_bus(7 DOWNTO 0);
clk_count := 0;
state <= send_data;
ELSE
busy <= '0';
rs <= '0';
rw <= '0';
clk_count := 0;
state <= ready;
END IF;
--send instruction to lcd
WHEN send_data =>
IF(clk_count < 2500) THEN
busy <= '1';
IF(clk_count > 100) THEN
e <= '0';
ELSE
e <= '1';
rs <= lcd_bus(9);
rw <= lcd_bus(8);
END IF;
state <= send_data;
ELSE
clk_count := 0;
busy <= '0';
state <= ready;
END IF;
END CASE;
--reset
IF(reset_n = '0') THEN
state <= power_up;
END IF;
END IF;
END PROCESS;
END controller;
