no_mad
Full Member level 5
Hi all,
Please share ur experience, ideas, thought or etc on this topic.
In my opinion, the 50% duty does not affect much, unless you are using phases as opposed to edges. That would be the case where you are using level-sensitive devices as opposed to edge-triggered ones.
An example that comes to mind is pipelining using latches. You could possibly run into problems in that case.
Thanks bansalr
bansalr wrote:
"The only problem if u don't have 50% duty cycle when timing is evaluated between negative edge and positive of the same clock. because the margin will be less in one of the case when duty cycle is not 50%.
others plz share. "
Thanks bansalr
