TJ Detweiler
Newbie level 3
- Joined
- Dec 10, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 29
I'm trying to build and piece an multistage amplifier with the specifications below:
1. Two inputs one plus , one negative
2. Capable of driving a 50 K ohm load to + 10 V
3. Frequency response DC - 10MHz + 2 db.
4. The input impedance must be at least 1 Megohm
5. The output impedance must be less than 50 ohms
6. Only discrete devices (BJT, FET, TUBES) may be used.
7. This amplifier will be packaged in such a way that it does not exceed more than 3 inches on any side.
8. Temperature range: 25 -- 100oC
9. The gain must be between 1000 - 1500
So far *attached is what I got (PSPICE) but I have trouble getting the gain to be atleast 1000. Also the frequency does not exactly match at ~8Mhz. I also tried building the circuit on board but is giving erroneous results. Can someone guide me on how to proceed to satisfy the requirements?
