Register Log in
Direction of Magnetic field
electronicsman
Full Member level 5
I am trying to understand the basics of magnetic field, if I know this answer i have one more clarification to ask
Based on the magnetic field is my representation of North and South pole correct. The magnetic field originates at North pole and ends at South pole?
Akanimo
Advanced Member level 2
How do you mean originate...and end...? The field direction does not imply movement of the field. It implies the existence of a static field that has the potential to cause influence on a magnetically polarized body in a predefined way. The direction of the field is just an arbitrary reference, just like we have +ve and -ve for electric field.
electronicsman
Full Member level 5
I come to the actual problem i want to understand
I am representing a stator with 3 winding's 120 degrees, I am trying to simulating rotating magnetic field. Now in a rotating magnetic field the net magnetic field Bs will be rotating, Similarly in the document there is North and South pole also rotating. So, I assume the magnetic field Bs can also be interpreted as North and South Pole. Am i correct? And one particular instant as shown in the diagram the Bs is pointing to right, so i assume the North and South pole are originating at one end and ending at the other end. I am not sure if it is just representation or it is the actual situation. Please correct me.
KlausST
Super Moderator
Staff member
hi,
unless you want to do some position control, then it makes no difference. the voltage will be positive and negative - in best case - according a sine shape.
But I see a little mistake in your picture.
a, c´, b, a´, c, b´ .. is correct. But the marking on <a> should be a dot and tthe marking at <a´> should be an X .. to get equal 120° aligned sine waveform.
Klaus
electronicsman
Full Member level 5
hi,
Klaus
But I am doing position control, can you please explain what i have asked.
Klaus
I have referred another website and the original document the representations are correct only. It is only current at a particular instant, not sure what is wrong. Please help.
c_mitra
Advanced Member level 5
Right.
The magnetic field is a vector field.
You place a test unit north pole at a given position position and the direction and magnitude of the force experienced by this test pole defines the magnetic field at that point.
The magnetic lines of forces are continuous; that means they travel from the south pole to the north pole within the magnetic material (this is an important difference from the electric lines of forces).
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
Magnetism arises from electron spin. There's one direction of spin, and there's the opposite direction. The field (or flux) doesn't originate from a particular place.
Nor does an electron spin 'north' and another 'south'.
A north pole is never separate from a south pole.
We call it north and south because a compass points north with the blue end of the needle even though in reality that end is magnetized to be a south pole. I don't know about you but it's become so I have trouble getting my mind around it.
electronicsman
Full Member level 5
I understand it is very tough for me to put across my questions, but this is what i am expecting, if see the bar magnet there is North and south pole and the field lines start from N and end at S. Similarly in the initial diagrams i wanted to know if they can be represented as N and the S poles based on the Magnetic field. Most of the time I am not sure if the question I ask makes sense or not.
c_mitra
Is not accurate; magnetism arises due to flow of charge or current. But yes, ferromagnetism, para and dia-magnetism are all intimately connected with the electron spin. Nuclear magnetism is primarily due to nuclear spin.
The diagram is wrong because it does not show the lines of forces within the magnet. Magnetic lines of forces are closed and continuous. You may please look up any standard book and see the drawings of the lines of forces for a solenoid.
Electric lines of forces always terminate on an equipotential surface: the lines of forces cannot cross the equipotential surface.
electronicsman
Full Member level 5
Klaus
Now i understand why you said this as per the below waveform
One of the currents is always in the negative direction and the other two positive to get a 120 Deg waveform. Hence one of them should be "." and other two "x"
venn_ng
Member level 5
Magnetic field always has a loop. This comes from maxwell's equation V.B =0. (V is the gradient operator) This equation says that divergence of magnetic field is 0.
This means, there is always a loop. I think in this case, it goes through the south pole and returns back to the north pole again
Easy peasy
Melbourne
on a compass, the N part is North seeking ( i.e. actually a South pole ) and the the S part is south seeking, i.e. a North pole
c_mitra
One of the currents is always in the negative direction and the other two positive to get a 120 Deg waveform. Hence one of them should be "." and other two ...
See your post #10.
If they are really 120 deg out of phase from each other, they identically vanish to zero. In other words, if you wind three coils on a former and feed each coil with the three phases, you will not get any magnetic field.
Or, if you prefer that way, you add pointwise the three graphs: at every point the total will be ZERO.
Toggle Sidebar
