lightspeeed
Newbie level 2
serial port led
Hi all,
Does anyone here have any experience hooking up a Maxim MAX7219 Serial Interface LED Display Driver directly to a PC serial port?
I am trying to do a simple Visual Basic application that would write directly to the PC serial port, which in turn, drives the MAX7219 to display stuff on a custom LED matrix.
I know most times these LED drivers are used in conjuction with microcontrollers for standalone operation. But my application will have the PC next to it at all times for other reasons, so I may as well use the built-in I/O of the PC (I'm thinking of virtual serial ports via USB).
I'm also aware that Maxim has published an application note that shows an implementation of the MAX7219/7221 where it directly talks to a PC parallel port to simulate serial activity.
The mystery to me here is that after quite a bit of searching, I still havent found anyone out there who has done a direct serial connection.
Please pardon me, Im not an electronics engineer, so if this is a stupid question - I'm sorry, in advance (I just need to be told that it is).
So, is there anything fundamentally and technically wrong about hooking the display driver as mentioned?
Thanks for any help!
Hi all,
