When can you directly connect scope probes without need of isolation transformer. I am aware that if you don't use transformer you run the risk of frying your scope. Is this only a problem when dealing with ac voltage. I asked a friend of mine this question and he said that if I wired a two prong plug ( no ground ) into a receptacle and then plugged my scope into this receptacle I could directly connect my scope probes without fear of shorting to ground. Looking for a second opinion. Thanks in advance.
