hello sir,
I'm new to pcb designing.iI'm using diptrace pcb software.I'm planing to make a screen to print pcb's.but in my printer i can get maximum A4 size paper.but my pcb is bigger than A4.I ask my screen maker can you make a screen using my diptrace pcb file. he told his machine are supported coreldraw,pdfand tif formats.what can i do to solve this problem?thank you sir.
hello sir,
You may find a Digital printing outlet or a DTP fellow who can print any files up to A3+ page and take a film out of it or give it directly to the PCB manufacturer.
OR
You may convert the DIP trace file to a PDF file from any PDF printing utilities and give it to your screen maker..
Hi suresh269,
I installed "Bullzip PDF Printer" SW_
its free downloadable & PCBs real size dont matter!
You dont need to make GBR for printouts your CAD schema or PCB over that .
You do printer select: "Bullzip..." and save into the output file, you can scale & handle it for x-y format ...
Its a very good tool!
K.
I tried a few of them. But the size is not exact. There are some errors in size while conversion.
How many of you tried and get good results. Please share
Yes..i use "PDFCreator-0_9_3_GPLGhostscript" and you can print any doccument provided you set the page size in relation to the same. regarding errors, No matter how it looks on the screen, when you print the said doccument, on a bigger paper,say A3, it should print 100% scale provided you select it. Cheers
