ljy4468
Full Member level 4
- Joined
- Jul 20, 2005
- Messages
- 232
- Helped
- 13
- Reputation
- 26
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- South Korea
- Activity points
- 3,023
Good day
I know that diode reverse recovery current occurs through
i) diode is forward biased
ii) diode current flows
iii) Then, negative bias is applied across diode.
iv) negative current (reverse recovery current) flows a while.
Isn't it??
And then I have a question.
i) diode is forward biased.
ii) but NO diode current flows
iii) then, negative bias is applied
there occurs reverse recovery current??
This is example of PFC boost converter (discontinuous mode).
The book says there's no recovery current at second case.
But I cannot understand.
Thanks in advance.
Regards.
Isn't it??
Thanks in advance.
Regards.
