noobler
Member level 2
noob question: I tested a diode fwd bias circuit measuring 12mA. When I applied negative voltage, I am expecting a very small I reading. The source meter can be set to negative voltage. Why am I seeing a negative current value? If I tried to swap polarity of voltage (and sourcemeter set to +V), the current is small but positive. Any ideas? thanks
