I was doing something today in my lab and used a 1N4004 diode which i supposed to limit the current source to 1A but it doesnt work! I got my power source from a DC adapter which is about 16V @ 2.2A and the output current from the diode is approximately 2A! 8O
I hv no idea y this occured. Could anyone explain to me?
That diode doesn't limit the current to 1A. That current is only the maximum allowed for this diode. Reason: there's a voltage drop of about 0.8V. At 1A this means the power loss of the diode is 0.8V * 1A = 0.8W. Now if the current is too high the diode will heat to much, the temperature of the junction increases to >>125°C and the diode will be damaged soon.
You'll need a current limiting circuit for that purpose; evtl an electric bulb will work too.
Diode itself is not a current limitter. Only appropriate circuits or other elements can limit the current. I think above answer has hit the nail on the head.
can u explain "power source from a DC adapter which is about 16V @ 2.2A"
got my power source from a DC adapter which is about 16V @ 2.2A and the output current from the diode is approximately 2A-----i think the currient is lost spending in resistance
Your data 16V@2.2A means that output voltage from PS is 16V at 2.2A load current. The output voltage depends on load current if it is not stabilized. Less load current will give you slightly higher output voltage.
Typical current limiting circuit.
Calculate value of R2 according to your needs and also choose transistor according to power/current requirements.
[/img]
Use a thermal fuse. I am sure they make them although I have never used one. You can use a transistor arrangement but it will affect the regulation if you so desire to regulate the voltage of the supply. Let's say you have 16v that is regulated. The regulator will maintain the 16v but a transistor configuration on the output will not regulate effectively. Your power supply should have a regulated current limiting feature.
He is using a DC adaptor so the current limiting function will be directly on the AC side. To current limit the AC side wouldn't you need to use a triac. That would require a pulse to turn it off. That might work. The trigger arrangent migh be little tricky.
