sgrao
Newbie level 1
I am trying to simulate S1G diode current Vs voltage graph with temperature as variable parameter.
I have used equations
Id = Is(Tmeas) * exp(((Vd-(Rs*Id))*q/(k*Tmeas*n))-)+(Gmin*Vd)
where Is(Tmeas) = Is_nom* pow((Tmeas/Ta),(XTi/n))*exp(((1/Ta)-(1/Tmeas))*q*Eg/n/k)
Ta - Ambient Temperature
Tmeas - Temperature at which current value is required
Id - Diode instantaneous current
Is_nom - Reverse saturation current = 7.08264E-9
Is(Tmeas) - Reverse saturation current @ Tmeas
Vd - Instantaneous diode voltage
Rs - Diode series resistance = 0.0243166 ohms
q - Charge of electron - 1.602E-19
k - Boltzmann's constant - 1.38062E-23
n - diode constant - 2
Gmin = 1E-12
Eg = 1.1eV
XTi - Saturation current temperature exponent = 3 considered
I am not getting values as per the graph shared by S1G diode supplier.
I would like to know whether diode series resistance, Saturation current temperature exponent are temperature dependent? If so what equations I need to consider to derive Rs and XTi as temperature dependent.
Also, would like to know if any parameters I need to consider to get exact values as in graph.
Gmin = 1E-12
Eg = 1.1eV
