Hi,I'm working on a project where I'm using 2 dimmers and giving input to control the dimming of loads
But getting a problem when I connect both the loads to 2 different dimmer modules and 1 load dimming is effecting 2nd load dimming
I think this may be due to noise in dimmers but unable to understand the reasons
Help appreciated
Thanks in advance
Are you saying you're using one processor to control two dimmers? And you think noise is the problem? There are many possible reasons, you need to look at your circuit with a scope. It's not clear, but I'm guessing you're sending some data stream to the processor. Maybe that's getting corrupted. Maybe you're code is wrong.
