i am using LDD700H as dimmer for the LEDs , i just want to confirm if what i am doing is right. I will be connecting the Vin negative (i.e negative 50v pin) to the micro GND and
I will not be connecting Vout GND to the micro GND.
is it ok ?
hi Klaus
but the datasheet clearly is saying do not connect Vin to Vout ?
also what you mean by "both ICs" ? i have only one IC thats a microcontoller.
oh sorry i misread your statement.
I have the LDD mounted on a seperate board with its own power supply and micro mounted on a seprate board with its own power supply. so connecting ground means just running one wire from the micro board to the LDD board?
