#!/bin/sh
# This is a shell archive (produced by GNU sharutils 4.6.3).
# To extract the files from this archive, save it to some FILE, remove
# everything before the `#!/bin/sh' line above, then type `sh FILE'.
lock_dir=_sh08436
# Made on 2007-12-31 16:41 CET by <xl@wzab>.
# Source directory was `/tmp/stack_fsm'.
# Existing files will *not* be overwritten, unless `-c' is specified.
# This shar contains:
# length mode name
# 9450 -rw-r--r-- lcd_ram.vhd
# 9307 -rw-r--r-- lcd_regs.vhd
# 3079 -rw-r--r-- lcd_test_tb.vhd
# 1242 -rw-r--r-- lcd_test.ucf
# 368 -rwxrw-r-- test.sh
MD5SUM=${MD5SUM-md5sum}
f=`${MD5SUM} --version | egrep '^md5sum .*(core|text)utils'`
test -n "${f}" && md5check=true || md5check=false
${md5check} || \
echo 'Note: not verifying md5sums. Consider installing GNU coreutils.'
save_IFS="${IFS}"
IFS="${IFS}:"
gettext_dir=FAILED
locale_dir=FAILED
first_param="$1"
for dir in $PATH
do
if test "$gettext_dir" = FAILED && test -f $dir/gettext \
&& ($dir/gettext --version >/dev/null 2>&1)
then
case `$dir/gettext --version 2>&1 | sed 1q` in
*GNU*) gettext_dir=$dir ;;
esac
fi
if test "$locale_dir" = FAILED && test -f $dir/shar \
&& ($dir/shar --print-text-domain-dir >/dev/null 2>&1)
then
locale_dir=`$dir/shar --print-text-domain-dir`
fi
done
IFS="$save_IFS"
if test "$locale_dir" = FAILED || test "$gettext_dir" = FAILED
then
echo=echo
else
TEXTDOMAINDIR=$locale_dir
export TEXTDOMAINDIR
TEXTDOMAIN=sharutils
export TEXTDOMAIN
echo="$gettext_dir/gettext -s"
fi
if (echo "testing\c"; echo 1,2,3) | grep c >/dev/null
then if (echo -n test; echo 1,2,3) | grep n >/dev/null
then shar_n= shar_c='
else shar_n=-n shar_c= ; fi
else shar_n= shar_c='\c' ; fi
f=shar-touch.$$
st1=200112312359.59
st2=123123592001.59
st2tr=123123592001.5 # old SysV 14-char limit
st3=1231235901
if touch -am -t ${st1} ${f} >/dev/null 2>&1 && \
test ! -f ${st1} && test -f ${f}; then
shar_touch='touch -am -t $1$2$3$4$5$6.$7 "$8"'
elif touch -am ${st2} ${f} >/dev/null 2>&1 && \
test ! -f ${st2} && test ! -f ${st2tr} && test -f ${f}; then
shar_touch='touch -am $3$4$5$6$1$2.$7 "$8"'
elif touch -am ${st3} ${f} >/dev/null 2>&1 && \
test ! -f ${st3} && test -f ${f}; then
shar_touch='touch -am $3$4$5$6$2 "$8"'
else
shar_touch=:
echo
${echo} 'WARNING: not restoring timestamps. Consider getting and'
${echo} 'installing GNU `touch'\'', distributed in GNU coreutils...'
echo
fi
rm -f ${st1} ${st2} ${st2tr} ${st3} ${f}
if test ! -d ${lock_dir}
then : ; else ${echo} 'lock directory '${lock_dir}' exists'
exit 1
fi
if mkdir ${lock_dir}
then ${echo} 'x - created lock directory `'${lock_dir}\''.'
else ${echo} 'x - failed to create lock directory `'${lock_dir}\''.'
exit 1
fi
# ============= lcd_ram.vhd ==============
if test -f 'lcd_ram.vhd' && test "$first_param" != -c; then
${echo} 'x -SKIPPING lcd_ram.vhd (file already exists)'
else
${echo} 'x - extracting lcd_ram.vhd (text)'
sed 's/^X//' << 'SHAR_EOF' > 'lcd_ram.vhd' &&
-- Title : LCD controller for Spartan 3E Starter Kit
-- Project :
-- File : lcd.vhd
-- Author : Wojciech M. Zabolotny <w...@ise.pw.edu.pl>
-- Company :
-- Created : 2007-12-31
-- Last update: 2007-12-31
-- Platform :
-- Standard : VHDL
-- Description: This is a sample implementation of state machine
-- with "state stack", which allows you to implement often used
-- sequences of states as "subroutines"
-- This is a slightly modified implementation - return requires
-- one clock cycle more, but the stack may be automatically
-- implemented in RAM
-- Copyright (c) 2007
-- This is public domain code!!!
-- Revisions :
-- Date Version Author Description
-- 2007-12-31 1.0 wzab Created
X
X
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
X
entity lcd_test is
X
X port (
X led : out std_logic_vector(7 downto 0);
X lcd : out std_logic_vector(7 downto 4);
X lcd_rs : out std_logic;
X lcd_rw : out std_logic;
X lcd_e : out std_logic;
X strataflash_oe : out std_logic;
X strataflash_we : out std_logic;
X strataflash_ce : out std_logic;
X sys_clk : in std_logic;
X sys_rst : in std_logic);
X
end lcd_test;
X
architecture beh of lcd_test is
X
X constant T_CLK : integer := 20; -- Clock period in ns
X type T_LCD_STATE is (L_START, L_WRITE, L_DELAY, L_RET, L_INIT0,
X L_INIT1, L_INIT2, L_INIT3, L_INIT4, L_INIT5, L_INIT6, L_INIT7,
X L_INIT8, L_INIT9, L_INIT10, L_INIT11, L_INIT12, L_INIT13, L_INIT14, L_INIT15,
X L_INIT16, L_INIT17, L_INIT18, L_INIT19, L_INIT20, L_INIT21, L_INIT22,
X L_WRITED, L_WRITED_1, L_WRITED_2, L_WRITED_3, L_WRITED_4,
X L_WRITE4, L_WRITE4_1, L_WRITE4_2, L_WRITE4_3,
X L_WRITE8, L_WRITE8_1, L_WRITE8_2);
X constant STACK_DEPTH : integer := 7;
X type T_STACK is array (STACK_DEPTH-1 downto 0) of T_LCD_STATE;
X signal stack : T_STACK;
X signal stack_ptr : integer range 0 to STACK_DEPTH := 0;
X signal stack_err : boolean := false;
X signal lcd_state : T_LCD_STATE := L_START;
X signal lcd_cmd : std_logic_vector(7 downto 0);
X signal cnt_del : integer := 0;
X
X signal main_clk, main_rst, main_rst0 : std_logic := '0';
X
begin -- beh
X
X strataflash_ce <= '0';
X strataflash_we <= '1';
X strataflash_oe <= '1';
X
X main_clk <= sys_clk;
X led(7) <= '1' when stack_err else '0';
X process (main_clk, sys_rst)
X begin -- process
X if sys_rst = '1' then -- asynchronous reset (active low)
X main_rst <= '0';
X main_rst0 <= '0';
X elsif main_clk'event and main_clk = '1' then -- rising clock edge
X main_rst0 <= '1';
X main_rst <= main_rst0;
X end if;
X end process;
X
X
X procedure STK_PUSH (
X constant next_state : in T_LCD_STATE) is
X begin -- STK_PUSH
X if stack_ptr < STACK_DEPTH then
X stack(stack_ptr) <= next_state;
X stack_ptr <= stack_ptr + 1;
X else
X stack_err <= true;
X end if;
X end STK_PUSH;
X
X procedure STK_RET is
X begin -- stk_pop
X if stack_ptr > 0 then
X stack_ptr <= stack_ptr - 1;
X lcd_state <= L_RET;
X else
X end if;
X end STK_RET;
X
X procedure STK_CALL (
X constant called_state, ret_state : in T_LCD_STATE) is
X begin -- STK_CALL
X STK_PUSH(ret_state);
X lcd_state <= called_state;
X end STK_CALL;
X
X procedure STK_JMP (
X constant called_state : in T_LCD_STATE) is
X begin -- STK_CALL
X end STK_JMP;
X
X procedure STK_DEL (
X constant delay : in integer;
X constant ret_state : in T_LCD_STATE) is
X begin -- stk_pop
X cnt_del <= (delay+T_CLK-1) / T_CLK;
X STK_CALL(L_DELAY, ret_state);
X end STK_DEL;
X
X procedure STK_WRITE4 (
X constant value4 : in integer range 0 to 15;
X begin -- STK_WRITE4
X lcd_rs <= '0';
X lcd_cmd(7 downto 4) <= std_logic_vector(to_unsigned(value4, 4));
X STK_CALL(L_WRITE4, ret_state);
X end STK_WRITE4;
X
X procedure STK_WRITE8 (
X constant value8 : in integer range 0 to 255;
X begin -- STK_WRITE8
X lcd_rs <= '0';
X lcd_cmd(7 downto 0) <= std_logic_vector(to_unsigned(value8, 8));
X STK_CALL(L_WRITE8, ret_state);
X end STK_WRITE8;
X
X procedure STK_WRITED (
X begin -- STK_WRITED
X lcd_rs <= '1';
X STK_CALL(L_WRITED, ret_state);
X end STK_WRITED;
X
X procedure INIT is
X begin -- INIT
X lcd_rw <= '0';
X lcd_e <= '0';
X lcd <= (others => '0');
X lcd_state <= L_START;
X led(6 downto 0) <= (others => '0');
X stack_err <= false;
X stack_ptr <= 0;
X cnt_del <= 0;
X end INIT;
X
X begin -- process
X INIT;
X if main_rst = '0' then
X INIT;
X else
X led(6 downto 4) <= std_logic_vector(to_unsigned(stack_ptr,3));
X case lcd_state is
X when L_START =>
X STK_DEL(16_000_000, L_INIT0);
X -- Subroutine DELAY
X when L_INIT0 =>
X led(0) <= '1';
X STK_WRITE4(16#3#, L_INIT1);
X when L_INIT1 =>
X STK_DEL(4_200_000, L_INIT2);
X when L_INIT2 =>
X STK_WRITE4(16#3#, L_INIT3);
X when L_INIT3 =>
X STK_DEL(110_000, L_INIT4);
X when L_INIT4 =>
X STK_WRITE4(16#3#, L_INIT5);
X when L_INIT5 =>
X STK_DEL(41_000, L_INIT6);
X when L_INIT6 =>
X STK_WRITE4(16#2#, L_INIT7);
X when L_INIT7 =>
X STK_DEL(41_000, L_INIT8);
X when L_INIT8 =>
X STK_WRITE8(16#28#, L_INIT9);
X when L_INIT9 =>
X STK_DEL(41_000, L_INIT10);
X when L_INIT10 =>
X STK_WRITE8(16#06#, L_INIT11);
X when L_INIT11 =>
X STK_DEL(41_000, L_INIT12);
X when L_INIT12 =>
X STK_WRITE8(16#0C#, L_INIT13);
X when L_INIT13 =>
X STK_DEL(41_000, L_INIT14);
X when L_INIT14 =>
X STK_WRITE8(16#01#, L_INIT15);
X when L_INIT15 =>
X STK_DEL(1_750_000, L_INIT16);
X when L_INIT16 =>
X STK_WRITED(16#45#, L_INIT17);
X when L_INIT17 =>
X STK_WRITED(16#46#, L_INIT18);
X when L_INIT18 =>
X STK_WRITED(16#47#, L_INIT19);
X when L_INIT19 =>
X STK_WRITED(16#48#, L_INIT20);
X when L_INIT20 =>
X STK_WRITED(16#49#, L_INIT21);
X when L_INIT21 =>
X STK_DEL(2_000_000_000,L_INIT20); -- we stay here forever
X when L_DELAY =>
X if cnt_del = 0 then
X STK_RET;
X else
X cnt_del <= cnt_del-1;
X end if;
X -- Subroutine WRITE4
X when L_WRITE4 =>
X led(3) <= '1';
X lcd_rw <= '0';
X lcd(7 downto 4) <= lcd_cmd(7 downto 4);
X STK_DEL(60, L_WRITE4_1);
X when L_WRITE4_1 =>
X lcd_e <= '1';
X STK_DEL(250, L_WRITE4_2);
X when L_WRITE4_2 =>
X lcd_e <= '0';
X STK_DEL(20, L_WRITE4_3);
X when L_WRITE4_3 =>
X led(3) <= '0';
X STK_RET;
X -- Subroutine WRITE8
X when L_WRITE8 =>
X led(2) <= '1';
X STK_CALL(L_WRITE4, L_WRITE8_1);
X when L_WRITE8_1 =>
X STK_DEL(1_000, L_WRITE8_2);
X when L_WRITE8_2 =>
X lcd_cmd(7 downto 4) <= lcd_cmd(3 downto 0);
X led(2) <= '0';
X STK_JMP(L_WRITE4);
X -- Subroutine WRITED
X when L_WRITED =>
X led(1) <= '1';
X STK_CALL(L_WRITE4, L_WRITED_1);
X when L_WRITED_1 =>
X STK_DEL(1_000, L_WRITED_2);
X when L_WRITED_2 =>
X STK_CALL(L_WRITE4, L_WRITED_3);
X when L_WRITED_3 =>
X STK_DEL(41_000, L_WRITED_4);
X when L_WRITED_4 =>
X --lcd_rs <= '0';
X led(1) <= '0';
X STK_RET;
X when L_RET =>
X lcd_state <= stack(stack_ptr);
X when others =>
X STK_JMP(L_INIT0);
X end case;
X end if;
X end if;
X end process;
end beh;
SHAR_EOF
(set 20 07 12 31 16 37 47 'lcd_ram.vhd'; eval "$shar_touch") &&
chmod 0644 'lcd_ram.vhd'
if test $? -ne 0
then ${echo} 'restore of lcd_ram.vhd failed'
fi
if ${md5check}
then (
${MD5SUM} -c >/dev/null 2>&1 || ${echo} 'lcd_ram.vhd: MD5 check failed'
) << SHAR_EOF
748c67b71f4dd43e9a3868200651f277 lcd_ram.vhd
SHAR_EOF
else
test `LC_ALL=C wc -c < 'lcd_ram.vhd'` -ne 9450 && \
${echo} 'restoration warning: size of lcd_ram.vhd is not 9450'
fi
fi
# ============= lcd_regs.vhd ==============
if test -f 'lcd_regs.vhd' && test "$first_param" != -c; then
${echo} 'x -SKIPPING lcd_regs.vhd (file already exists)'
else
${echo} 'x - extracting lcd_regs.vhd (text)'
sed 's/^X//' << 'SHAR_EOF' > 'lcd_regs.vhd' &&
-- Project :
-- File : lcd.vhd
-- Company :
-- Platform :
-- Standard : VHDL
-- This implementation uses registers to implement the stack.
-- Revisions :
X
X
library ieee;
X
entity lcd_test is
X
X port (
X
end lcd_test;
X
X
X type T_LCD_STATE is (L_START, L_WRITE, L_DELAY, L_INIT0,
X
X
begin -- beh
X
X
X begin -- process
X main_rst <= '0';
X main_rst0 <= '0';
X main_rst0 <= '1';
X end if;
X end process;
X
X
X begin -- STK_PUSH
X else
X end if;
X end STK_PUSH;
X
X begin -- stk_pop
X lcd_state <= stack(stack_ptr - 1);
X else
X end if;
X end STK_RET;
X
X begin -- STK_CALL
X end STK_CALL;
X
X begin -- STK_CALL
X end STK_JMP;
X
X begin -- stk_pop
X end STK_DEL;
X
X lcd_rs <= '0';
X end STK_WRITE4;
X
X lcd_rs <= '0';
X end STK_WRITE8;
X
X lcd_rs <= '1';
X end STK_WRITED;
X
X procedure INIT is
X begin -- INIT
X lcd_rw <= '0';
X lcd_e <= '0';
X stack_ptr <= 0;
X cnt_del <= 0;
X end INIT;
X
X begin -- process
X INIT;
X INIT;
X else
X case lcd_state is
X when L_START =>
X when L_INIT0 =>
X led(0) <= '1';
X when L_INIT1 =>
X when L_INIT2 =>
X when L_INIT3 =>
X when L_INIT4 =>
X when L_INIT5 =>
X when L_INIT6 =>
X when L_INIT7 =>
X when L_INIT8 =>
X when L_INIT9 =>
X when L_INIT10 =>
X when L_INIT11 =>
X when L_INIT12 =>
X when L_INIT13 =>
X when L_INIT14 =>
X when L_INIT15 =>
X when L_INIT16 =>
X when L_INIT17 =>
X when L_INIT18 =>
X when L_INIT19 =>
X when L_INIT20 =>
X when L_INIT21 =>
X when L_DELAY =>
X STK_RET;
X else
X end if;
X when L_WRITE4 =>
X led(3) <= '1';
X lcd_rw <= '0';
X lcd_e <= '1';
X lcd_e <= '0';
X led(3) <= '0';
X STK_RET;
X when L_WRITE8 =>
X led(2) <= '1';
X led(2) <= '0';
X when L_WRITED =>
X led(1) <= '1';
X --lcd_rs <= '0';
X led(1) <= '0';
X STK_RET;
X when others =>
X STK_JMP(L_INIT0);
X end case;
X end if;
X end if;
X end process;
end beh;
SHAR_EOF
(set 20 07 12 31 16 41 15 'lcd_regs.vhd'; eval "$shar_touch") &&
chmod 0644 'lcd_regs.vhd'
if test $? -ne 0
then ${echo} 'restore of lcd_regs.vhd failed'
fi
if ${md5check}
then (
${MD5SUM} -c >/dev/null 2>&1 || ${echo} 'lcd_regs.vhd: MD5 check failed'
) << SHAR_EOF
55c5d9ed49dd08fa9d839c2b9b9e8f41 lcd_regs.vhd
SHAR_EOF
else
test `LC_ALL=C wc -c < 'lcd_regs.vhd'` -ne 9307 && \
${echo} 'restoration warning: size of lcd_regs.vhd is not 9307'
fi
fi
# ============= lcd_test_tb.vhd ==============
if test -f 'lcd_test_tb.vhd' && test "$first_param" != -c; then
${echo} 'x -SKIPPING lcd_test_tb.vhd (file already exists)'
else
${echo} 'x - extracting lcd_test_tb.vhd (text)'
sed 's/^X//' << 'SHAR_EOF' > 'lcd_test_tb.vhd' &&
-- Title : Testbench for design "lcd_test"
-- Project :
-- File : lcd_test_tb.vhd
-- Author :
-- Company :
-- Created : 2007-12-30
-- Last update: 2007-12-30
-- Platform :
-- Standard : VHDL'87
-- Description:
-- Revisions :
-- 2007-12-30 1.0 xl Created
X
library ieee;
X
X
entity lcd_test_tb is
X
end lcd_test_tb;
X
X
architecture test of lcd_test_tb is
X
X component lcd_test
X port (
X end component;
X
X -- component ports
X signal led : std_logic_vector(7 downto 0);
X signal lcd : std_logic_vector(7 downto 4);
X signal lcd_rs : std_logic;
X signal lcd_rw : std_logic;
X signal lcd_e : std_logic;
X signal strataflash_oe : std_logic;
X signal strataflash_we : std_logic;
X signal strataflash_ce : std_logic;
X signal main_clk : std_logic;
X signal main_rst : std_logic;
X
X -- clock
X signal Clk : std_logic := '1';
X
begin -- test
X
X -- component instantiation
X DUT: lcd_test
X port map (
X led => led,
X lcd => lcd,
X lcd_rs => lcd_rs,
X lcd_rw => lcd_rw,
X lcd_e => lcd_e,
X strataflash_oe => strataflash_oe,
X strataflash_we => strataflash_we,
X strataflash_ce => strataflash_ce,
X sys_clk => main_clk,
X sys_rst => main_rst);
X
X -- clock generation
X Clk <= not Clk after 10 ns;
X main_clk <= Clk;
X
X -- waveform generation
X WaveGen_Proc: process
X begin
X -- insert signal assignments here
X main_rst <= '1';
X wait until Clk = '1';
X wait for 300 ns;
X main_rst <= '0';
X wait for 500_000_000 ns;
X end process WaveGen_Proc;
X
X
X
end test;
X
X
configuration lcd_test_tb_test_cfg of lcd_test_tb is
X for test
X end for;
end lcd_test_tb_test_cfg;
X
SHAR_EOF
(set 20 07 12 31 01 14 25 'lcd_test_tb.vhd'; eval "$shar_touch") &&
chmod 0644 'lcd_test_tb.vhd'
if test $? -ne 0
then ${echo} 'restore of lcd_test_tb.vhd failed'
fi
if ${md5check}
then (
${MD5SUM} -c >/dev/null 2>&1 || ${echo} 'lcd_test_tb.vhd: MD5 check failed'
) << SHAR_EOF
d601df1b5aa846da3f477cdd4eff918b lcd_test_tb.vhd
SHAR_EOF
else
test `LC_ALL=C wc -c < 'lcd_test_tb.vhd'` -ne 3079 && \
${echo} 'restoration warning: size of lcd_test_tb.vhd is not 3079'
fi
fi
# ============= lcd_test.ucf ==============
if test -f 'lcd_test.ucf' && test "$first_param" != -c; then
${echo} 'x -SKIPPING lcd_test.ucf (file already exists)'
else
${echo} 'x - extracting lcd_test.ucf (text)'
sed 's/^X//' << 'SHAR_EOF' > 'lcd_test.ucf' &&
NET "LED[7]" LOC = "F12" | IOSTANDARD = "LVCMOS33";
NET "LED[6]" LOC = "E12" | IOSTANDARD = "LVCMOS33";
NET "LED[5]" LOC = "E11" | IOSTANDARD = "LVCMOS33";
NET "LED[4]" LOC = "F11" | IOSTANDARD = "LVCMOS33";
NET "LED[3]" LOC = "C11" | IOSTANDARD = "LVCMOS33";
NET "LED[2]" LOC = "D11" | IOSTANDARD = "LVCMOS33";
NET "LED[1]" LOC = "E9" | IOSTANDARD = "LVCMOS33";
NET "LED[0]" LOC = "F9" | IOSTANDARD = "LVCMOS33";
NET "LCD[7]" LOC = "M15" | IOSTANDARD = "LVCMOS33";
NET "LCD[6]" LOC = "P17" | IOSTANDARD = "LVCMOS33";
NET "LCD[5]" LOC = "R16" | IOSTANDARD = "LVCMOS33";
NET "LCD[4]" LOC = "R15" | IOSTANDARD = "LVCMOS33";
NET "LCD_RS" LOC = "L18" | IOSTANDARD = "LVCMOS33";
NET "LCD_RW" LOC = "L17" | IOSTANDARD = "LVCMOS33";
NET "LCD_E" LOC = "M18" | IOSTANDARD = "LVCMOS33";
NET "STRATAFLASH_OE" LOC = "C18" | IOSTANDARD = "LVCMOS33";
NET "STRATAFLASH_WE" LOC = "D17" | IOSTANDARD = "LVCMOS33";
NET "STRATAFLASH_CE" LOC = "D16" | IOSTANDARD = "LVCMOS33";
NET "SYS_CLK" LOC = "C9" | IOSTANDARD = "LVCMOS33";
NET "SYS_RST" LOC = "K17" | IOSTANDARD = "LVCMOS33" | PULLDOWN;
NET "sys_clk" TNM_NET = "sys_clk";
TIMESPEC "TS_sys_clk" = PERIOD "sys_clk" 20 ns HIGH 50 %;
OFFSET = IN 10 ns BEFORE "sys_clk" ;
OFFSET = OUT 10 ns AFTER "sys_clk" ;
SHAR_EOF
(set 20 07 12 30 23 10 46 'lcd_test.ucf'; eval "$shar_touch") &&
chmod 0644 'lcd_test.ucf'
if test $? -ne 0
then ${echo} 'restore of lcd_test.ucf failed'
fi
if ${md5check}
then (
${MD5SUM} -c >/dev/null 2>&1 || ${echo} 'lcd_test.ucf: MD5 check failed'
) << SHAR_EOF
802f00a019965e0d378e2cf3d4d1d5d3 lcd_test.ucf
SHAR_EOF
else
test `LC_ALL=C wc -c < 'lcd_test.ucf'` -ne 1242 && \
${echo} 'restoration warning: size of lcd_test.ucf is not 1242'
fi
fi
# ============= test.sh ==============
if test -f 'test.sh' && test "$first_param" != -c; then
${echo} 'x -SKIPPING test.sh (file already exists)'
else
${echo} 'x - extracting test.sh (text)'
sed 's/^X//' << 'SHAR_EOF' > 'test.sh' &&
#!/bin/bash
set -e
# Compile the VHDL
VHDLS="\
X lcd_ram.vhd \
X lcd_test_tb.vhd \
X "
STD=standard
mkdir -p work
#STD=synopsys
ghdl -a --workdir=work --std=02 --ieee=$STD $VHDLS
ghdl -e --workdir=work --std=02 --ieee=$STD lcd_test_tb
# Run the simulation
X./lcd_test_tb --wave=lcd.ghw --stop-time=10000000ns
# Let'us view the recorded waveforms
gtkwave lcd.ghw lcd.sav
SHAR_EOF
(set 20 07 12 31 16 34 06 'test.sh'; eval "$shar_touch") &&
chmod 0764 'test.sh'
if test $? -ne 0
then ${echo} 'restore of test.sh failed'
fi
if ${md5check}
then (
${MD5SUM} -c >/dev/null 2>&1 || ${echo} 'test.sh: MD5 check failed'
) << SHAR_EOF
93fc50b3bec3d00c88e6af999e8da36d test.sh
SHAR_EOF
else
test `LC_ALL=C wc -c < 'test.sh'` -ne 368 && \
${echo} 'restoration warning: size of test.sh is not 368'
fi
fi
if rm -fr ${lock_dir}
then ${echo} 'x - removed lock directory `'${lock_dir}\''.'
else ${echo} 'x - failed to remove lock directory `'${lock_dir}\''.'
exit 1
fi
exit 0
