Mar 9, 2018 #1 F flote21 Advanced Member level 1 Joined Jan 22, 2014 Messages 411 Helped 1 Reputation 2 Reaction score 3 Trophy points 1,298 Activity points 5,595 Hello folks, I am trying to find a commercial Digital Level Shifter Part from 24V to 15V. Anyone knows anything? I need to reduce the voltage of some PWM signals... Thanks in advance Greetings
Mar 9, 2018 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,173 Helped 4,868 Reputation 9,757 Reaction score 5,541 Trophy points 1,393 Activity points 168,428 Hi, Two resistors as voltage divider. Klaus
Mar 9, 2018 #3 F flote21 Advanced Member level 1 Joined Jan 22, 2014 Messages 411 Helped 1 Reputation 2 Reaction score 3 Trophy points 1,298 Activity points 5,595 Hi KlauSt, Thanks for your quick answer. However is not so easy because the PWM signal comes from other PCB board with the next ouput driver: Greetings KlausST said: Hi, Two resistors as voltage divider. Klaus Click to expand...
Mar 9, 2018 #4 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,173 Helped 4,868 Reputation 9,757 Reaction score 5,541 Trophy points 1,393 Activity points 168,428 Hi, and where is the problem with the voltage divider? *** Your schematic shows MOSFET drivers. Currently they are supplied with 24V. Why not simply supply them with 15V? Klaus
Mar 14, 2018 #5 F flote21 Advanced Member level 1 Joined Jan 22, 2014 Messages 411 Helped 1 Reputation 2 Reaction score 3 Trophy points 1,298 Activity points 5,595 Hi KlauST, Right, there is not any problem with the voltage divider. Thanks! Greetings KlausST said: Hi, and where is the problem with the voltage divider? *** Your schematic shows MOSFET drivers. Currently they are supplied with 24V. Why not simply supply them with 15V? Klaus Click to expand...
