Right now I'm learning the basics of the digital filters using external a/d and d/a converter board attached to pc parallel port. I’m working under ms-dos using djgpp c compiler and nasm assembler for writing code to get data from a/d converter via parallel port and return processed data to d/a converter via same port.(data collection using inp and oup in C and some processing using assembly function.)
I wish to know, is there any simulation software available in which I could simulate external a/d and d/a board, write some code (using c and assembly) and test that code on the simulated hardware without plugging any external boards etc. to my PC.
Thanks in advance.
agnivesh
