I understand that digital error correction for a pipeline ADC which is based on 1.5 bit per stage
is used in order to correct offsets from comparator, opamp, etc. My question is, how does
it actually correct this offset? What is the exact mechanism that allows you to be able
to tolerate a larger comparator offset just because you have digital correction. The way I
see it, the digitial correction is just a bunch of adders!
... how does it actually correct this offset?
What is the exact mechanism that allows you to be able to tolerate a larger comparator offset just because you have digital correction.
A comprehensive description of the RSD mechanism can be found here: B. Ginetti, P.G.A. Jespers, and A. Vandemeulebroecke, “A CMOS 13-b cyclic RSD A/D converter”
IEEE Journal of Solid-State Circuits, vol. 27, pp. 957–964, July 1992.
