oh sure...there's a lot of examples in this forum that will help you. You can use then. Go in Search and try Control inside this (FPGA,PLD,etc) forum....good luck
thanks for reply ! but im gettin' things mix right now .. u said digital systems could be implemented via PLDs indeed ! but can u give me an example of control system..
in other words can i control for example a speed of a DC motor via PLDs??
i hope im clear
i can suggest u design using pld to implement a PWM then try to connect the output to a lowpast filter to create the signal to control ur motor. but don't connect the motor directly to the pld, it will overload the pld. use a motor driver. hope this helps.
