naspek
Member level 1
i've already done the assembly language for my digital lock code project..
however.. when i simulate it using EdSim51, nothing came out from the lcd..
can someone please guide me to solve this problem?
[/code]
lcd_port equ P3
en equ P3.7
rs equ P3.5
lock equ P1.3
LCD_CLR equ 01H
LCD_LN1 equ 80H
LCD_LN2 equ 0C0H
LOCK_i equ 0
UNLOCK_i equ 1
EX_i equ 2
OK_i equ 3
var1 equ r2
temp equ r3
delay equ r4
scan equ r5
iskey equ 0H
newcode equ 1H
keyval equ r6
status equ r7
max equ 30H
count equ 31H
length equ 32H
retries equ 33H
input equ 40H
upass equ 50H
is_ok equ 2H
FALSE equ 0
TRUE equ 1
RETRY equ 2
EXIT equ 3
keyport equ P1
col1 equ P1.0
col2 equ P1.1
col3 equ P1.2
org 0H
acall lcd_init
acall keypad_init
clr iskey
mov sp,#60H
mov retries,#3
main:
mov a,#LCD_CLR
acall lcd_cmd
mov dptr,#str_enter
acall lcd_str
mov a,#0C0H
acall lcd_cmd
mov a,#LOCK_i
acall lcd_dat
mov a,#':'
acall lcd_dat
mov max,#5
acall get_input
cjne status,#TRUE,main
mov dptr,#chk_12345
mov count,#5
acall chk
jnb is_ok,main_2
acall set_upass
sjmp main
main_2:
jb newcode,main_3
mov dptr,#chk_upass
mov count,#5
acall chk
sjmp main_4
main_3:
acall chk_newcode
main_4:
jnb is_ok, main_5
mov retries,#3
clr lock
mov a,#LCD_CLR
acall lcd_cmd
mov a,#OK_i
acall lcd_dat
mov dptr,#inactive
acall lcd_str
mov a,#LCD_LN2
acall lcd_cmd
mov dptr,#inactive1
acall lcd_str
acall delay_1sec
mov a,#LCD_CLR
acall lcd_cmd
mov dptr,#inactive2
acall lcd_str
mov a,#LCD_LN2
acall lcd_cmd
mov dptr,#inactive3
acall lcd_str
main_6:
acall get_key
cjne keyval,#12,main_6
setb lock
mov a,#LCD_CLR
acall lcd_cmd
mov a,#OK_i
acall lcd_dat
mov dptr,#active
acall lcd_str
acall delay_1sec
ajmp main
main_5:
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov a,#EX_i
acall lcd_dat
mov a,#2FH
add a,retries
acall lcd_dat
mov dptr,#str_retry
acall lcd_str
acall delay_1sec
djnz retries,main_8
sjmp main_7
main_8:
ajmp main
main_7:
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov a,#EX_i
acall lcd_dat
mov dptr,#str_blocked
acall lcd_str
mov a,#EX_i
acall lcd_dat
mov a,#LCD_LN2
acall lcd_cmd
mov a,#LOCK_i
acall lcd_dat
mov a,#':'
acall lcd_dat
mov max,#10
acall get_input
mov count,#10
mov dptr,#chk_master
acall chk
jnb is_ok, main_7
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov a,#OK_i
acall lcd_dat
mov dptr,#str_unblocked
acall lcd_str
acall delay_1sec
mov retries, #3
main_1:
ajmp main
str_enter:
db 'E', 'n', 't', 'e', 'r', ' ', 'l', 'o', 'c', 'k', ' ', 'C', 'o', 'd', 'e',0
str_master:
db 'E', 'n', 't', 'e', 'r', ' ', 'M', 'a', 's', 't', 'e', 'r', ' ', 'c', 'o', 'd', 'e', 0
str_retry:
db 'T', 'r', 'i', 'e', 's', ' ', 'l', 'e', 'f', 't', 0
str_blocked:
db 'B', 'l', 'o', 'c', 'k', 'e', 'd',0
str_unblocked:
db 'U', 'n', 'b', 'l', 'o', 'c', 'k', 'e', 'd',0
inactive:
db 'L', 'o', 'c', 'k', ' ', 'i', 's',0
inactive1:
db 'd', 'e', 'a', 'c', 't', 'i', 'v', 'a', 't', 'e', 'd', '!', 0
inactive2:
db 'P', 'r', 'e', 's', 's', ' ', '#', ' ', 'k', 'e', 'y', ' ', 't', 'o', 0
inactive3:
db 'l', 'o', 'c', 'k', ' ', ' ', 'a', 'g', 'a', 'i', 'n', 0
active:
db 'L', 'o', 'c', 'k', ' ', 'i', 's', ' ', 'a', 'c', 't', 'i', 'v', 'e', '!', 0
lcd_reset:
mov lcd_port, #0FFH
mov delay,#20
acall delayms
mov lcd_port, #83H
mov lcd_port, #03H
mov delay,#15
acall delayms
mov lcd_port, #83H
mov lcd_port, #03H
mov delay,#5
acall delayms
mov lcd_port, #83H
mov lcd_port, #03H
mov delay,#5
acall delayms
mov lcd_port, #82H
mov lcd_port, #02H
mov delay,#5
acall delayms
ret
lcd_init:
acall lcd_reset
mov a,#28H
acall lcd_cmd
mov a,#0CH
acall lcd_cmd
mov a,#06H
acall lcd_cmd
mov a,#80H
acall lcd_cmd
acall cgbuild
ret
cgbuild:
mov count,#32
mov a,#40H
acall lcd_cmd
mov dptr,#icons
cgbuild_l1:
clr a
movc a,@a+dptr
acall lcd_dat
inc dptr
djnz count,cgbuild_l1
ret
lcd_cmd:
mov temp,a
swap a
anl a,#0FH
add a,#80H
mov lcd_port,a
anl a,#0FH
mov lcd_port,a
mov a,temp
anl a,#0FH
add a,#80H
mov lcd_port,a
anl a,#0FH
mov lcd_port,a
mov delay,#10
acall delayms
ret
lcd_dat:
mov temp,a
swap a
anl a,#0FH
add a,#0A0H
mov lcd_port,a
nop
clr en
mov a,temp
anl a,#0FH
add a,#0A0H
mov lcd_port,a
nop
clr en
mov delay,#10
acall delayms
ret
lcd_str:
clr a
movc a,@a+dptr
jz lcd_str_end
inc dptr
acall lcd_dat
sjmp lcd_str
lcd_str_end:
ret
lcd_str1:
clr a
mov a,@r0
jz lcd_str_end1
inc r0
acall lcd_dat
sjmp lcd_str1
lcd_str_end1:
ret
delayms:
mov var1,#230
d:
nop
nop
djnz var1,d
djnz delay,delayms
ret
keypad_init:
anl keyport,#0FH
ret
get_key:
mov keyval,#1
mov a,#80H
mov temp,#04
read:
mov scan,a
cpl a
anl keyport,a
jb col1,next
jnb col1,$
setb iskey
ret
next:
jb col2,next1
inc keyval
jnb col2,$
setb iskey
ret
next1:
jb col3,nokey
inc keyval
inc keyval
jnb col3,$
setb iskey
ret
nokey:
mov a,scan
orl keyport,a
inc keyval
inc keyval
inc keyval
rr a
mov delay,#10
acall delayms
djnz temp,read
clr iskey
ret
translate:
mov a,keyval
cjne a,#10,jmp1
mov keyval,#'x'
ret
jmp1:
cjne a,#11,jmp2
mov keyval,#'0'
ret
jmp2:
cjne a,#12,jmp3
mov keyval,#'e'
ret
jmp3:
add a,#'0'
mov keyval,a
ret
get_input:
mov r0,#input
mov count,#0
inc max
get_input_cnt:
acall get_key
jnb iskey,get_input_cnt
acall translate
mov a, keyval
mov @r0,a
cjne @r0,#'x',chk_e
mov a,count
jnz get_input_l1
mov status,#EXIT
ret
get_input_l1:
inc max
dec count
mov @r0,#0
dec r0
mov a,#0C2H
add a,count
acall lcd_cmd
mov a,#' '
acall lcd_dat
mov a,#0C2H
add a,count
acall lcd_cmd
sjmp get_input_cnt
chk_e:
cjne @r0,#'e',chk_key
mov @r0,#0
dec max
mov a,max
jnz get_input_lerr
mov status,#TRUE
ret
chk_key:
inc count
djnz max, get_input_nxt
mov dptr,#get_input_err
get_input_retry:
mov input,#0
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov a,#EX_i
acall lcd_dat
acall lcd_str
acall delay_1sec
mov status,#RETRY
ret
get_input_nxt:
mov a,@r0
acall lcd_dat
inc r0
sjmp get_input_cnt
get_input_lerr:
mov dptr,#get_input_err1
sjmp get_input_retry
get_input_err1:
db 'C', 'o', 'd', 'e', ' ', 'i', 's', ' ', 's', 'm', 'a', 'l', 'l', '.', '.', '.', 0
get_input_err:
db 'C', 'o', 'd', 'e', ' ', 'i', 's', ' ', 'l', 'o', 'n', 'g', '.', '.', '.', '.', 0
chk:
mov r0,#input
chk_l2:
clr a
movc a,@a+dptr
mov b,@r0
cjne a,b,chk_l1
inc dptr
inc r0
djnz count,chk_l2
setb is_ok
ret
chk_l1:
clr is_ok
ret
chk_newcode:
mov count,#5
mov r0,#input
mov r1,#upass
chk_newcode_l1:
mov a,@r0
mov b,@r1
cjne a,b,chk_newcode_l2
inc r0
inc r1
djnz count, chk_newcode_l1
setb is_ok
ret
chk_newcode_l2:
clr is_ok
ret
chk_12345:
db '1', '2', '3', '4', '5',0
chk_master:
db '1', '2', '3', '4', '5', '6', '7', '8', '9', '0',0
chk_upass:
db '5', '4', '3', '2', '1',0
set_upass:
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov dptr,#str_master
acall lcd_str
mov a,#LCD_LN2
acall lcd_cmd
mov a,#LOCK_i
acall lcd_dat
mov a,#':'
acall lcd_dat
mov max,#10
acall get_input
cjne status,#TRUE,set_upass_l1
mov count,#10
acall chk
jnb is_ok,set_upass_l1
set_upass_l4:
mov a,#LCD_CLR
acall lcd_cmd
mov a,#LCD_LN1
acall lcd_cmd
mov dptr,#str_new
acall lcd_str
mov a,#LCD_LN2
acall lcd_cmd
mov a,#LOCK_i
acall lcd_dat
mov a,#':'
acall lcd_dat
mov max,#5
acall get_input
cjne status,#TRUE, set_upass_l5
mov a,#LCD_CLR
acall lcd_cmd
mov a,#OK_i
acall lcd_dat
mov dptr,#str_saved
acall lcd_str
setb newcode
acall copy_code
acall delay_1sec
ret
set_upass_l5:
cjne status,#RETRY,set_upass_l2
sjmp set_upass_l4
set_upass_l1:
sjmp set_upass
set_upass_l2:
ret
str_new:
db 'E', 'n', 't', 'e', 'r', ' ', 'n', 'e', 'w', ' ', 'c', 'o', 'd', 'e', 0
str_saved:
db 'L', 'o', 'c', 'k', ' ', 'c', 'o', 'd', 'e', ' ', 's', 'a', 'v', 'e', 'd', '!', 0
copy_code:
mov r0,#input
mov r1,#upass
mov count,#5
copy_code_l1:
mov a,@r0
mov @r1,a
inc r0
inc r1
djnz count, copy_code_l1
ret
delay_1sec:
mov delay,#250
acall delayms
mov delay,#250
acall delayms
mov delay,#250
acall delayms
mov delay,#250
acall delayms
ret
icons:
db 0xe, 0xa, 0x1f, 0x1f, 0x1b, 0x1b, 0xe, 0x0, 0xe, 0x2, 0x1f, 0x1f, 0x1b, 0x1b, 0xe, 0x0, 0x1f, 0x1b, 0x1b, 0x1b, 0x1b, 0x1f, 0x1b, 0x1f, 0x0, 0x1, 0x3, 0x16, 0x1c, 0x8, 0x0, 0x0
end
