[SOLVED] Digital Clock using 89s52/89c52
adambose1990
Kolkata, India
Hi guys, here is a simple project I have done in 89s52 IC of 8051 series. Making a Digital Clock.
Components required:
1 microcontroller 89C52(89S52 will also do)
2 ceramic capacitors-22pF
1 switch(button for reset purpose)
1 electrolytic capacitor-10uF,25V
1 crystal oscillator-11.0592MHz
16x2 LCD display
1 resistor-10k
Software you will need:
The programming of the microcontroller is done using keil compiler. Port 2 is output port, This LCD is in 8bit mode.
Details of LCD you can have here.
Circuit Diagram:
The detail explanation of the code is done below:
CODE:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
//main.c
#include <REG51.H>
#include "lcd.h"
void ms_delay(int time)
        unsigned int i,j;
        for(i=0;i<time; i++)
                for(j=0;j<=1275;j++);
void main(void)
        int hr=00,min=00,sec=00,flag=0;
        LCD_init();
        LCD_putnum(hr,2);                  //|HH:MM:SS  AM
        LCD_sendstring(":");
        LCD_putnum(min,2);
        LCD_putnum(sec,2);
        LCD_sendstring("  AM");
   while(1)
        for (sec=0;sec<60;sec++)
                LCD_gotoxy(6,0);
                LCD_putnum(sec,2);
                ms_delay(142);
                if (sec==59)
                        min=min+1;
                        if(min==60)
                                if(hr==11&&sec==59)
                                        hr=0;
                                        min=0;
                                        sec=-1;
                                        flag=~flag;
                                        LCD_gotoxy(0,0);
                                        LCD_putnum(hr,2);
                                        LCD_gotoxy(3,0);
                                        LCD_putnum(min,2);
                                        LCD_gotoxy(10,0);
                                        if (flag==0)
                                                LCD_sendstring("AM");
                                        else
                                                LCD_sendstring("PM");
                                else
                                        hr=hr+1;
                                        min=0;
                                        LCD_gotoxy(0,0);
                                        LCD_putnum(hr,2);
                                        LCD_gotoxy(3,0);
                                        LCD_putnum(min,2);
                        LCD_gotoxy(3,0);
                        LCD_putnum(min,2);
But before that you have to make lcd.h file. Its codes are given also here. This Header is specially made for this program.
CODE:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
//lcd.h
#ifndef __LCD_H__
#define __LCD_H__
#define LCD_data P2
void _LCD_busy(void);
void _LCD_sdelay(void);
void _LCD_poweron(void);
void _LCD_command(unsigned char);
void _LCD_senddata(unsigned char);
void _LCD_sendstring(unsigned char *);
void _LCD_putnum(int, int);
void _LCD_init(void);
void _LCD_clear(void);
sbit LCD_rs=P1^0;
sbit LCD_rw=P1^1;
sbit LCD_en=P1^2;
void LCD_busy()
    unsigned char i,j;
        for(i=0;i<50;i++)
                for(j=0;j<255;j++);
void LCD_sdelay()
    unsigned char i;
        for(i=0;i<50;i++);
void LCD_poweron()
unsigned int i;
for (i=0;i<22500; i++);
void LCD_command(unsigned char var)
     LCD_data  = var;      //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rs   = 0;        //Selected command register
     LCD_rw   = 0;        //We are writing in instruction register
     LCD_en   = 1;        //Enable H->L
     LCD_en   = 0;
     LCD_busy();          //Wait for LCD to process the command
void LCD_putnum(int number,int width)// LCD_putnum: Implementing integer value from -99999 to 99999
   unsigned char digit;
   if (number < 0)
     LCD_senddata('-');
         LCD_sdelay();
         number = -1 * number;
   switch (width)
                case 5:
                        digit = '0';
                        while(number >= 10000)                // Keep Looping for larger than 10
                        digit++;                         // Increase ASCII character
                        number -= 10000;                    // Subtract number with 10
                        LCD_senddata(digit);                // Put the Second digit
                        LCD_sdelay();
           case 4:
                        digit = '0';
                        while(number >= 1000)                // Keep Looping for larger than 10
                        number -= 1000;                    // Subtract number with 10
                        LCD_sdelay();
                case 3:
                        digit = '0';
                        while(number >= 100)                // Keep Looping for larger than 10
                        number -= 100;                    // Subtract number with 10
                        LCD_sdelay();
                case 2:
                        digit = '0';
                        while(number >= 10)                // Keep Looping for larger than 10
                        number -= 10;                    // Subtract number with 10
                        LCD_sdelay();
                case 1:
                        LCD_senddata('0' + number);           // Put the First digit
                        LCD_sdelay();
void LCD_sendstring(unsigned char *var)
     while(*var)              //till string ends
       LCD_senddata(*var++);  //send characters one by one
void LCD_senddata(unsigned char var)
     P2  = var;      //Function set: 2 Line, 8-bit, 5x7 dots
     LCD_rs   = 1;        //Selected data register
     LCD_en   = 0;
     //LCD_busy();          //Wait for LCD to process the command
void LCD_init(void)
     LCD_data = 0x38;     //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rw   = 0;        //We are writing in data register
     LCD_en   = 0;
     LCD_data  = 0x0C;     //Display on, Curson blinking off command
     LCD_en   = 0;
     LCD_data  = 0x01;     //Clear LCD
     LCD_en   = 0;
     LCD_data  = 0x06;     //Entry mode, auto increment with no shift
     LCD_en   = 0;        //Enable H->L
     LCD_busy();
void LCD_clear(void)
    LCD_en   = 0;
    LCD_busy();
void LCD_gotoxy(int x, int y)//x=0..16, y= 0..1
  int dr;
  if (y==0)
        dr=x+0x80;
  if (y==1)
    dr=x+0xC0;
  LCD_data  = dr;      //Function set: 2 Line, 8-bit, 5x8 dots
  LCD_en   = 0;
  LCD_busy();
#endif
Thanks a lot...
For any quarries you can contact adambose1990@gmail.com
You can download the following attachents
.Hex file
.H file
.C file // for keil
.DSN file // for proteus
They are all in rar file. Extract them all.
View attachment Desktop.rar
Without a RTC chip, using C compiler --- How accurate is your clock?
dear frnds ...........em making digital base clock and At89c51........em posting coad in c....plz help me it is right....
sbit LCD_RS at P3_7_bit;
sbit LCD_EN at P3_6_bit;
sbit LCD_D0 at P2_0_bit;
sbit LCD_D1 at P2_1_bit;
sbit LCD_D2 at P2_2_bit;
sbit LCD_D3 at P2_3_bit;
sbit LCD_D4 at P2_4_bit;
sbit LCD_D5 at P2_5_bit;
sbit LCD_D6 at P2_6_bit;
sbit LCD_D7 at P2_7_bit;
Lcd_Init(); // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR); // lcd clear
void main(void)
int hr=00,min=00,sec=00;
LCD_init();
LCD_chr(1,1,hr); //|HH:MM:SS AM
LCD_out(1,4,":");
LCD_chr(1,6,min);
LCD_out(1,8,":");
LCD_chr(1,10,sec);
while(1)
LCD_chr(1,10,sec);
if (sec==59)
min=min+1;
if(min==60)
if(hr==11&&sec==59)
hr=0;
min=0;
sec=-1;
LCD_chr(1,1,hr);
LCD_chr(1,6,min);
else
hr=hr+1;
min=0;
LCD_chr(1,1,hr);
LCD_chr(1,6,min);
LCD_chr(1,6,min);
