rohanmartin08
Newbie level 2
I have written a code for digital clock. Is the following code correct?
#include <AT892051.H>
#include <stdio.h>
#include <intrins.h>
sbit DigitShiftregisterSerialPin=P1^0; /* Character to be transfered through thisbit in parallel*/
sbit DigitShiftregisterClockPin=P1^1; /* Clock*/
sbit DigitShiftregisterLatchPin=P1^2; /* Latch*/
sbit DriveMinutes=P1^3; /* 1st 7-segment Display*/
sbit DriveTensMinutes=P1^4; /* 2nd 7-segment Display*/
sbit DriveHours=P1^5; /* 3rd 7-segment Display*/
sbit DriveTensHours=P1^6; /* 4th 7-segment Display*/
unsigned char SevenSegmentData;
unsigned char _crol_(unsigned char Temp,unsigned char SevenSegmentData);
char Display_Buffer[4];
int Dispcount;
int mscount;
int Hours=0;
int Minutes=0;
int Seconds=0;
char Temp;
code unsigned char DecimalToSevenSegment[11]=
0xEE,0x28,0xCD,0x6C,0x2B,0x67,0xE7,0x2C,0xEF,0x2F
void main()
TMOD=0x01;
TH0=0xF8; /* Initializing timer0 for 1ms*/
TL0=0x30;
IE=0x82;
TR0=1;
do
sprintf(Display_Buffer,"%02d%02d",Minutes,Hours); /* converting integer into character*/
}while(1);
void Timer0(void) interrupt 1 /* ISR begins*/
TF0=0;
TR0=0;
TH0=0xF8;
TL0=0x30;
TR0=1;
/* To transfer bits into byte from port pin onto the shift register*/
Dispcount++; /* Dispcount is used to refresh the Hours and Minutes on the LED*/
mscount++; /* Generate 1ms Delay*/
if(mscount>=1000)
mscount=0;
Seconds++;
if(Seconds>=60)
Seconds=0;
Minutes++;
if(Minutes>=60)
Minutes=0;
Hours++;
if(Hours>=13)
Hours=1;
// For LED's
int i,j=1;
if(Dispcount==29) /* This code is for refresh rate */
DriveMinutes=0;
DriveTensMinutes=0;
DriveHours=0;
DriveTensHours=0;
if(Dispcount==30)
if(j<=4)
SevenSegmentData=DecimalToSevenSegment[Display_Buffer[j]-'0'];
if (Dispcount==32)
Temp=SevenSegmentData;
DigitShiftregisterClockPin=1; /* clock is set high*/
if(8>i) /* For a byte to be read by the port pin*/
if (Dispcount==34)
/*if (Dispcount==36)
DigitShiftregisterSerialPin=Temp^7; /* Taking MSB one at a time, the loop continous till all 8-bits are sent to the portpin
if (Dispcount==38 )
DigitShiftregisterClockPin=0; /*clock is made low*/
if (Dispcount==40)
SevenSegmentData=_crol_(Temp,1); /* bits are rotated left*/
DigitShiftregisterLatchPin=0; /* Data is Latched*/
if(Display_Buffer[1])
DriveTensHours=1;
if(Display_Buffer[2])
DriveHours=1;
if(Display_Buffer[3])
DriveTensMinutes=1;
if(Display_Buffer[4])
DriveMinutes=1;
#include <stdio.h>
int Dispcount;
int mscount;
int Hours=0;
int Minutes=0;
int Seconds=0;
char Temp;
void main()
TMOD=0x01;
TL0=0x30;
IE=0x82;
TR0=1;
do
}while(1);
TF0=0;
TR0=0;
TH0=0xF8;
TL0=0x30;
TR0=1;
if(mscount>=1000)
mscount=0;
Seconds++;
if(Seconds>=60)
Seconds=0;
Minutes++;
if(Minutes>=60)
Minutes=0;
Hours++;
if(Hours>=13)
Hours=1;
// For LED's
int i,j=1;
DriveMinutes=0;
DriveTensMinutes=0;
DriveHours=0;
DriveTensHours=0;
if(Dispcount==30)
if(j<=4)
if (Dispcount==32)
if (Dispcount==34)
if (Dispcount==38 )
if (Dispcount==40)
DriveTensHours=1;
DriveHours=1;
DriveTensMinutes=1;
DriveMinutes=1;
