operation of ic ua741
hello,
I was working on an differential amplifier for DC voltages. After some simulating with Pspice i found out that for small voltage differences it won't work.
In the attachment of this mail you will find some pictures of the simulation results. In fig. 1 you will see the first simulation. Voltage source V1 has a voltage 4V and V2 a voltage of 3V at the output the voltage is 1V, so this is perfect. In figure 2 I narrowd the difference to only 0.1V. The output of the amp is now 0.4V(388mV). This is not good. As you can see the supply voltage of the opamp is on the positive pin 15V and the negative pin 0V. If i now make the negative supply pin -1V (fig.3) it works fine again, with the same difference of 0.1V between V1 and V2. How is this possible? is this the result of the voltage offset?. I only have a power supply of +15V does anyone know a simple ciruict with transistors or someting to make -1V out of +15V?
I hope that someone can help me
greets Rudie
