imrankhanPNU
Member level 1
Hello,
I am designing a differential isolator via a capacitive coupling technique in which a control signal is differentially modulated and coupled capacitively to the differential demodulator side.
I have designed a demodulator using single-stage Opamp and LPF [Schematics attached]. The problem is the LPF's output signal swings between 2.8V to 5 V. How can I make LPF's output signal swing between 0-5V?
By doing so will make the Schmitt trigger's job easy to retrieve the output signal.
Thanks.
Thanks.
